> IS IT POSSILBE TO MAKE 7age
post Oct 17, 2004 - 5:29 PM
st_celica_killer
Joined Sep 23, '04
From fresno
Hi i heard and did tons of research already so dont ask me to go do
anymore..anyways.......is 7age possible useing a 4age 16v complete head with
ecu and harnes.... on a 7afe block....... and what kinda of timing blet to
used....since its taller then stock..............aslo it is possible to used ITB on the
head ?? how hard is it to rewire the harness on a 94 celica st.......thank you all for helping .............................. .. GOING N/A .. ALL MOTOR
post Oct 17, 2004 - 6:05 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
DO RESEARCH SOME MORE!
post Oct 18, 2004 - 12:01 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Yes yes... do a bit of searching here. I've posted about it in detail on at least a few occasions...
post Oct 18, 2004 - 12:26 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!
<<<<<< DCw / JDMart >>>>>>>
post Oct 18, 2004 - 9:44 AM
nik
Joined Sep 30, '02
http://www.6gc.net/forums/index.php?showtopic=17020 rolleyes.gif this has a link to some 7age info but before you ask use the search button right top hand corner alot of these subjects have been talked about atleast once. wink.gif wink.gif
post Oct 19, 2004 - 4:54 PM
st_celica_killer
Joined Sep 23, '04
From fresno
WHAT YEAR DOES THE Porsche 924 HAS TO BE..?? CAUZ I NEED THE TIMMING BELT RIGHT NOW TO COMPLET THE SWAP.........???????THANK FOR YEA HELP.!!!
post Oct 19, 2004 - 5:56 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (st_celica_killer @ Oct 19, 2004 - 9:54 PM)
This is one of the VERY few porsche's to ever run an inline 4... so there is only one engine option. I think it's also one of the very few FR layout Porsches... anyway... model years are 76-81 If I remember correctly... or is it 83? I dunno... 76 to early 80's.
post Oct 19, 2004 - 11:13 PM
FallenHero
Joined Dec 26, '02
From Alabama
www.club4ag.com
This post has been edited by FallenHero: Oct 19, 2004 - 11:13 PM
post Oct 20, 2004 - 7:53 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE (Kwanza26 @ Oct 19, 2004 - 10:56 PM)
I thought it was the '86. I'm pretty sure it is, the '86 944. But I could be wrong....
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 21, 2004 - 2:06 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (raven_101 @ Oct 21, 2004 - 12:53 AM)
Umm... my old-school porsche knowledge isn't all that... but the two cars share the same engine of different generations I believe... one turbo one n/a. I believe the timing belt may be the same between the two... but no-one ever confirms anything. Some people use one belt, some people use the other... and yes... the 944 is a mid eighties model...
post Oct 21, 2004 - 9:46 AM
FallenHero
Joined Dec 26, '02
From Alabama
most I have read about use the 924 cam belt...
post Oct 21, 2004 - 9:38 PM
st_celica_killer
Joined Sep 23, '04
From fresno
I FOUND a 86 mr2 N/A...4AGE..BLUE TOP head.....comes complete with harness and ecu.. ...for $170 would it be a price to pay??... is it worth to built the 4age blue top head....and putting it on the stock 7afe block..???? and aslo the wiring..is it hard to connet . .??? and is it drive-able?? ...........need help..quickly..............???
post Oct 21, 2004 - 9:45 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
the blue top wasnt really a power maker. if your going for it you should go all out a find a mapped black top.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 21, 2004 - 9:52 PM
st_celica_killer
Joined Sep 23, '04
From fresno
so your saying that even i built the 4age blue top...its not really worth it.....and u say i should go with black top...which its hellllllla $$$$$$$$$$$..just for the complete 4age 20v head..........so its better to go cheap the $$$$$ when its almost the same..??? so is it worth building 4age blue top..it????? i heard ....Horsepower, then go will the BLUE TOP[/URL] http://www.toyotacelicaonline.com/celica1/7ahybrid.htm
This post has been edited by st_celica_killer: Oct 21, 2004 - 10:09 PM
post Oct 21, 2004 - 11:36 PM
Dr_Tweak
Joined Mar 31, '04
As I mentioned in your other thread, (by the way, you really should stick to one...), the bluetop is the oldest of the 4AGEs. Personally, I would not go through the trouble of a 7AGE with the bluetop. You can get a silvertop or blacktop head off eBay for a decent price, just be patient. You could also try posting a WTB ad at www.club4ag.com
-JD
post Oct 22, 2004 - 1:28 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (recneps @ Oct 22, 2004 - 2:45 AM)
I disagree... but the new heads (smallport, 20V) are far better. I've made some fair power out of bluetop 4AGs...
Anyway... if you are really gonna go n/a 7AGE... at least go with a smallport head (90+ corolla GTS, 90+ Prizm GSI). That head is far better for an n/a set-up because the ports aren't overly "big".
As for a 20V... slightly more difficult because of a lack of good diagrams... but do-able. It would be one of the first... unless of course you can beat me to it. I would choose a 20V because of it having 20 valves... I like the factory ITBs.
post Oct 22, 2004 - 6:46 AM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
I presently have a 7agte in my celica with blue top. I use the ae86 ecu (afm) and wiring with bad result (not compatible with e-manage) ... I will update this winter for an 4agze ecu (map dli setup). Even if you go n/a (with the red top) , to have the full potential of the hybrid you have to go piggy back or stand alone to change the timming/injection curves and it`s impossible with the sucking afm.
Claude
post Oct 22, 2004 - 11:06 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE (Kwanza26 @ Oct 21, 2004 - 11:28 PM)
I have looked at the 20V head.,... but the variable timing confuses me.
it looks like a regular head when you take the valve cover off. Could you run it without the variable timing?
post Oct 22, 2004 - 12:04 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (frotou @ Oct 22, 2004 - 11:46 AM)
Claude
YEah... the AFM and the crappy stock USDM and Canada ECUs do creat all sorts of tunig hazards. I suggest you look into Megasquirt. It's a DIY standalone unit with a LOT of tuning capabilities and can eliminate the AFM and stock ECU.
post Oct 22, 2004 - 12:09 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (FallenHero @ Oct 22, 2004 - 4:06 PM)
Variable Valve Timing works with the intake cam gear. It has nothing to do with the head design really... aside from oil passeages and stuff. Basically, on the silvertop 20V... VVT kicks on at 4000 rpms and the ECU sends a signal to the VVT solenoid and the solenoid acutates the VVT. It works like a computer controlled Cam Gear that advances 15 degrees. It doesn't make a huge difference, but it does increase top-end response. On VVT-i models, the VVT solenoid is always active and can retard and/or advance the intake timing any time depending on rpm, throttle, and conditions. Usually VVT-i is only on the intake side, with exception to the 3SGE BEAMS Blacktop which had it on both intake and exhaust.
And yes... you can run the engine without trouble without the VVT. I'm currently waiting on a set of cam gears for mine... =]
This post has been edited by Kwanza26: Oct 22, 2004 - 12:10 PM
Lo-Fi Version Time is now: May 25th, 2026 - 2:15 PM
