> 7afte
post Nov 8, 2004 - 10:33 AM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
i was wondering how to go about making my soon to be turbo 7A, a really strong and reliable engine, i am going to run roughly 5-8psi, until i put in 4agze pistons and new head gasket, my goal is to have about 225 wheel hp, does anyone have any suggestions on how to acheive this goal, i am goin got get larger injectors and a supra fuel pump, i have a garrett T3 turbo, how much boost can a stock 7a block take? please help me out...
-Jeremy
post Nov 8, 2004 - 10:34 AM
edo17982
Joined Dec 21, '02
From Italy
post Nov 8, 2004 - 10:46 AM
nik
Joined Sep 30, '02
http://www.importperformanceparts.net/imports/pek-geo.html here is a rebuild kit with 7afe pistons that are 8.5:1 pistons, copper head gasket, rods, and some toda stuff. biggrin.gif
post Nov 8, 2004 - 11:55 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
whoa, this is a good find for those wanting to turbo the 7a
post Nov 8, 2004 - 5:23 PM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
thanks Nik, good find!
post Nov 8, 2004 - 11:50 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Nik, wow buddy, great find there. That's only a couple hours from here, I could drive down there to get stuff.
Irishflame27, you are on the right track. Just remember to use good engine management and tune carefully. The GZE pistons are great, thought that deal from IPP is worth it. You should be able to run 12 psi or so, I would be careful running more than that. Before you up the boost past 12, do your other stuff first like porting the head (or swapping a GE head on) and so forth.
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 9, 2004 - 12:28 AM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
thanks alot Raven you have really helped me out here and on VVTi as well!
post Nov 9, 2004 - 7:21 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (nik @ Nov 8, 2004 - 8:46 AM)
that is a weak kit..
remember the weak point of the 7afe engine is the conecting rod..
even with that kit you cant push past 12 psi ( i know it lowers compression allowing you to boost more ect ect.. but it doesnt fix the weak connection rod problem)
what does the freeze plug do?
This post has been edited by Hanyo: Nov 9, 2004 - 7:22 AM
post Nov 9, 2004 - 11:11 AM
Jeremy1210
Joined Dec 16, '02
How is that kit weak? I don't get it??
post Nov 9, 2004 - 12:25 PM
nik
Joined Sep 30, '02
I sent Roy from PSI RACING a e-mail asking him what he did internally on his 7afte he ran 14.4 on 15 psi http://www.mr2supercharger.com/7Aengines.html the artical is in the middle of the page.
Lo-Fi Version Time is now: August 29th, 2026 - 7:52 AM
