Nov 18, 2004 - 5:03 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
After then Fallenhero posted topic about Civic pistons i'v made a few researches
Basicly piston diameter (bore) of b16 and 7A are the same (81 mm stock) Wrist Pin diameter is a bit different 7A is 20 mm and B16 is 21 mm but this is not a problem this way we guys will be able to use forged pistons from B16, and tehy are cheaper then toyota pistons -------------------- Ex celica owner - just a guy from other side of the pond...
Nov 18, 2004 - 10:23 AM
i'll ask the performance shop near me they should have some pistons on hand
Nov 18, 2004 - 10:47 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
ok, from what I have seen the regular honda pistons are Hella domed. However, the Low comp honda pistons are almost flat like 7a units, and should work pretty well. Hey doggy, did you see any info on using honda rods? That is, after all, one of the major 7a weaknesses. What is the crank diameter on a 7a? Any clue?
Nov 18, 2004 - 12:13 PM
towards the end of this post guys were talking about the 2zz rods, pistons, etc MIGHT fit no hard facts yet. http://www.6gc.net/forums/index.php?showtopic=11094&st=40
but buy the b16 low comp coated pistons with 2zz rods i wounder if it would work. -------------------- yea your 3sgte is cool but ill stick to my 7agte
Nov 18, 2004 - 1:45 PM
Enthusiast ![]() Joined Jul 24, '04 From Va Currently Offline Reputation: 0 (0%) |
QUOTE(nik @ Nov 18, 2004 - 5:13 PM) but buy the b16 low comp coated pistons with 2zz rods i wounder if it would work. [right][snapback]208547[/snapback][/right] B16 low compression pistons are low compression for hondas but due to head differences they might not be so low for toyotas. Any idea on the combustion chamber size difference between b16 and 7a? This post has been edited by Fox-N-It2: Nov 18, 2004 - 1:50 PM |
Nov 18, 2004 - 11:45 PM
QUOTE(Fox-N-It2 @ Nov 18, 2004 - 11:45 AM) QUOTE(nik @ Nov 18, 2004 - 5:13 PM) but buy the b16 low comp coated pistons with 2zz rods i wounder if it would work. [right][snapback]208547[/snapback][/right] B16 low compression pistons are low compression for hondas but due to head differences they might not be so low for toyotas. Any idea on the combustion chamber size difference between b16 and 7a? [right][snapback]208577[/snapback][/right] yea, that's the point. |
Nov 19, 2004 - 8:59 AM
Enthusiast ![]() Joined Sep 3, '04 From Avondale, AZ Currently Offline Reputation: 0 (0%) |
i am really interested to see if these would work, that would be awesome if they do!
Nov 19, 2004 - 1:07 PM
Enthusiast ![]() ![]() ![]() Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
Thats funny so the heart of your toyota engine is a honda. isint that like jungle feaver lol. Good find though im interested to see if they work even though im almost positive im going to swap.
Nov 19, 2004 - 2:56 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) |
Honda B series low-comp pistons probably won't lower compression in the 7AFE. Just consider 4AGZ pistons are the low-comp counterparts to 4AGE pistons, which are not domed... even if the B16 lowcomp pistons are flat... they still may not lower compression. Even so... it'll make a good n/a piston... but so will a 4AGE piston... with less hassle. Good price + machining work is probably gonna be more than 4AG pistons. 4AG pistons only run a bit more than B16 pistons. Also... if you plan on machining the piston... better get forged pistons. Cast pistons tends to crack and stress...
Doggy... 2ZZGE pistons have been fitted in a 7A block (7AGE hybrid)... The rods on the other hand... are still in question... -------------------- "It's ok to be naked girl... I'm an artist!"
Nov 19, 2004 - 3:07 PM
Enthusiast ![]() Joined Oct 1, '04 From Michigan Currently Offline Reputation: 0 (0%) |
May be off topic but i was looking at these for a 7agte i was planning on starting but im not sure what the compression would be the same as its listed ... or if they would even fit.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW |
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:01 PM |
