> map sensor mounting, peak a boo
post Dec 15, 2004 - 8:44 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
all right all of you 5sfte people out there i was wondering how you guys mounted your 2 bar map sensor either from an mr2 or a celica i have both sensors and the all trac one is like tack welded to the mount and the mr2 has nothing attached to it. i was wondering if you guys made a special bracket for it or what
post Dec 16, 2004 - 8:19 AM
post Dec 16, 2004 - 10:05 AM
Thats what I did, it just inclips you dont even have to take it off the firewall.
post Dec 17, 2004 - 3:18 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
but the harness is on the oppsoiste side n the wires aren't long enough...
post Dec 17, 2004 - 3:20 PM
??? you should be able to just unplug yours, and plug the new one in..
1bwilson
Joined Aug 30, '02
From Maryland
I put mine on upside down.
Member of Team 5sfTe
post Dec 18, 2004 - 8:13 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
the map sensor from an MR2 is different then one from an alltrac.... they may be mechanically the same but the way its mounted is completly different...
Im guessing you have the Mr2 one because my shop tried that one and was gona ghetto rig something to install it... but the alltrac one is lined up and will attach to your stock bracket.
Therefor you will need to just figure something out if you have the mr2 one.
post Dec 19, 2004 - 12:27 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i have both... and by the way the sensor should be mounted upright to let the moisture out i think.
post Dec 19, 2004 - 3:47 PM
Chrobis
Joined Apr 15, '03
well if you have an alltrac one, remove it from the alltrac mount and put it on your current mount.
post Dec 20, 2004 - 1:07 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
the mount is like tack weleded to the sensor or something it doesn't slip off like the stock 5s one does and the mr2 2 bar one.
post Dec 21, 2004 - 4:07 PM
Chrobis
Joined Apr 15, '03
I ordered a brand new alltrac map sensor, and it came with that bracket, I kinda had to break a little plastic on the map sensor to get it off the bracket, which I tried my best not to do. If you peel back the sticker you will see how it is held on and will be able to work at it better.
Lo-Fi Version Time is now: September 4th, 2026 - 2:10 PM
