Dec 26, 2004 - 2:57 PM
Enthusiast ![]() Joined May 24, '04 From Pittsfield Mass Currently Offline Reputation: 0 (0%) |
k well I just got a digital video camera and i want to know how to get my movies of my I can put the pics onto the computer using the USB cable and for some reason I cant import the videos using the USB cable. There is a slot for a DV (digital video) cable and im wondering if i have2 buy that cable in order to import movies onto your computer.???????????
Dec 26, 2004 - 3:01 PM
Depends what kind of camera. Have you installed the software that came with the camera?
Dec 26, 2004 - 3:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 30, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
6GGT Ehmmm...i have to know what actually you want to do with your camera and your computer??You want to edit in realtime or just to watch what you captured??If you want to edit in realtime i recommend to you to get a realtime board like Matrox RTX100 Pro Suite and ingest what you captured with your camera in your pc and edit it with Adobe Premiere Pro 1.5(its bundle with Matrox RTX100),make your realtime effects,slow motions,color correction and many many other things,have a check on the link i post to you.
If you just want to transfer your video footage on your pc but not in realtime you will need just a firewire cheap board and a software like premerie or windows movie if you are using windows xp. http://www.matrox.com/video/products/rtx10...emepro/home.cfm Please try to use and a second hard drive if you want to edit in serious mode. |
Dec 26, 2004 - 4:31 PM
so can you use the USB cable to transmit video?.......I have a JVC miniDV by the way, if that helps
Dec 26, 2004 - 7:06 PM
QUOTE(6GGT @ Dec 26, 2004 - 9:31 PM) so can you use the USB cable to transmit video?.......I have a JVC miniDV by the way, if that helps [right][snapback]226670[/snapback][/right] that USB cable is for the digital photo stick option your card has. to transfer the video to your computer you need an IEEE1394 (firewire ilink) cable and some software. Both should have come with your camera |
Dec 26, 2004 - 7:18 PM
how about read the manual ???
Dec 26, 2004 - 7:20 PM
Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From New York City, NY Currently Offline Reputation: 1 (100%) |
If you dont have a firewire port (IEEE1394) buy a PCI firewire add-on, a firewire cable & if you got windows XP, use the XP movie maker. You'll most likely need the drivers for the dv-cam & that is the simplest way to do it.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 8:42 PM |
