Dec 27, 2004 - 12:07 PM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
i only have 600 rms going through my system. i was wondering if you guys replaced the big 3 and if it helped out at all. my 400w amp is class d and my 200w amp is class a/b.
Dec 27, 2004 - 12:41 PM
Enthusiast ![]() ![]() Joined Nov 8, '04 From Carmi, Illinois Currently Offline Reputation: 0 (0%) |
a/b amps draw alot of current. replacing your altenator and battery will not stop dimming completely... but it is a must have in the car audio world if you want the most out of your system.
-------------------- i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U. TrickedOutS2000: it was a vibrator my dad bought scarr3ll: WHAT THE ****?!?11 TrickedOutS2000: yeh TrickedOutS2000: for my mom im guessing TrickedOutS2000: but yeah TrickedOutS2000: eww TrickedOutS2000: so TrickedOutS2000: ****ing TrickedOutS2000: wrong My Cardomain Page. Car Audio Central msn: jared_s_c@hotmail.com aim: Scarr3ll |
Dec 27, 2004 - 1:28 PM
im not THAT serious about it. its just an annoyance. i was just wondering about the big 3 because i dont want to spend any more money.
Dec 27, 2004 - 1:30 PM
I'm pumping 700W total with no headlight dimming
*shrug* new battery, class d mono amp. |
Dec 27, 2004 - 1:54 PM
ah ok, i thought you said you did replace em and it was still happening. it is always a good idea to get a new battery and altenator and ofcourse new wiring for this stuff. for some people it can still happen(dimming) but when replacing this stuff it will not happen as bad.
Dec 27, 2004 - 2:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
The big three is upgrading wires, not battery and alt. It would definitaly be a good idea to upgrade... just replacing my grounds i noticed a difference with my headlights dimming.
Dec 27, 2004 - 3:18 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
I think getting a capacitor would solve the light dimming problem.
http://www.cardomain.com/shoptype/Stiffening+Capacitors -------------------- |
Dec 27, 2004 - 4:32 PM
caps wont solve the problem. ugrade the big three, and if that doesnt work and your willing to spend the cash, upgrade the alternator.
Dec 27, 2004 - 5:07 PM
A cap would "solve" the light dimmer problem; but it really only just hides the larger problems until it all comes crashing down.
Dec 27, 2004 - 11:59 PM
a cap doesnt solve anything, it just takes the charge instead of the battery, and the cap itself takes current.. caps are a "if you want one, but you dont have to have it" type of thing.
Dec 28, 2004 - 12:50 AM
well a cap would work fine at hiding the dimming for like bass drums where its real quick and the cap can handle it, but for like a bass sine wave or bass guitar forget it. it cant do a damn thing.
Dec 28, 2004 - 7:49 AM
as i said, its one of those "if you want one" type of things.
Dec 28, 2004 - 8:41 AM
get bigger ENGINE ground wires and find a better ground for your amp
Dec 28, 2004 - 6:14 PM
why does the engine have a ground?
Dec 28, 2004 - 6:32 PM
QUOTE(rocky2006 @ Dec 28, 2004 - 11:14 PM) why does the engine have a ground? [right][snapback]227476[/snapback][/right] Because it'd catch on fire or do lots of nasty things. |
Dec 29, 2004 - 1:35 AM
cause it has electricity
Dec 29, 2004 - 6:20 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
all the metal rubbing metal, and spinning friction blah blah blah, all you need to know is: it go boom with no ground.
I have no idea what class my amp is but it makes my lights dim a bit two, can go really dim during a long instance. I recomend the following - Optima red top batt. - better hylogen(sp) head light bulbs, that take less power - 2 guage wire (what I have, for + and the ground) - A good cap (if you only pushing 600w then that is enough to stop the dimming, any more is overkill i think.) I will be having bigger problems when i re-wire mine for 2 ohm, (1600w 800 rms) but well see. or do the real easy thing, and hook a small 12v batt. up to your head lights so they have there own to help when the system cant give full power to it. This post has been edited by creis: Dec 29, 2004 - 6:22 AM -------------------- ![]() |
| Lo-Fi Version | Time is now: September 21st, 2026 - 1:43 AM |
