> Two questions!!, Two Stupid questions i know !!!
post Jan 6, 2005 - 10:14 AM
KyoKusanagi
Joined Apr 21, '03
From Kitchener ,Ontario Canada
Anywayz just wanted too see what you guys though or too see your posts on these two questions 1) what the hell is the overdirve for on automatics? i know it's dumb but i never did find out and 2nd anyone here ever have this problem when i first looked into my celi it was listed as a 94 GT so i was like cool so i went too look at it i didn't know jack about the 6th gen and i bought it then i found out from the graces of our site that i had bought a ST frown.gif so anywayz when i got my insurance everytime they put in my VIN it came up a GT even though i had an ST anyone ever have this problem? man i wish it was a real GT anywayz my ST has every option including pwr everything and ST stock alloy rims not hubs only the engine is a 7afe damn thing anywayz just wanted too see what you guys thought take care Payce!
11
post Jan 6, 2005 - 10:47 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
okay for your first question, all overdrive for a auto does is downshifts from D (4th gear) to 3rd if u need to catch some speed to while trying to pass a car or somthing like that. on a regular basis u would want it on for gas milage.
and second question, it sounds like you have an STX which is a st with all the gt options. I think you should talk to your insurence and prove to them that u don't have a gt.
Team 6gc 2005
post Jan 6, 2005 - 10:55 AM
shid
Joined Jan 8, '04
From LA
QUOTE(Drocay @ Jan 6, 2005 - 3:47 PM)
okay for your first question, all overdrive for a auto does is downshifts from D (4th gear) to 3rd if u need to catch some speed to while trying to pass a car or somthing like that. on a regular basis u would want it on for gas milage.[right][snapback]230632[/snapback][/right]
This is incorrect. The overdrive acts as forth gear, it IS a forth gear. If you have the OD off, you won't get any further than 3rd gear. If you have the OD on, the automatic tranny will shift to 4th to save engine wear and tear while you're trying to rev up in third. This makes the third gear shift out very early. If you have OD off, you can take third all the way up, turn the OD on and then it'll shift into OD, or 4th.
post Jan 6, 2005 - 11:42 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
thats wut i meant.
Team 6gc 2005
post Jan 10, 2005 - 2:41 PM
97GTinKC
From KC
QUOTE(KyoKusanagi @ Jan 6, 2005 - 8:14 AM)
11
[right][snapback]230619[/snapback][/right]
I've even seen some ST's with a small gold GT badge on the rear hatch (apparently there were some "dealer installed" gold trim packages. kind of an underhanded way to make one look like a GT. find the VIN breakdown to tell for sure, also should definitely have rear disk brakes if it is a GT
Lo-Fi Version Time is now: August 27th, 2026 - 12:40 AM
