Jan 12, 2005 - 5:27 AM
Enthusiast ![]() Joined Sep 5, '02 From Peoria, IL Currently Offline Reputation: 0 (0%) |
Well, I got the invader kit. The backbumper fit good, the sides fit great......and the front, no good. The highbeam holes are like an inch-1inch 1/2 out. Im thinking that metal saftey bar is getting in the way, yes I saw the post below about the guy modifying it. My bodykit guy says if thats the problem, we are going 2 remove it but replace it with a metal bar to hold some stability.
So my question, for the kit to fit great, does the bar have to be removed/modified...r did I get a junk front end? |
Jan 12, 2005 - 8:46 AM
DON"T TOUH THE BAR>>>>only a stupid person would do that or a person who doesn't drive their car due to show...bkholer for example
it will fill with thebar you just have to knotch it out for it to fit around the bar and if that doesn't work you can...slightly modify the headlight tabs to extend to the bumper or you can glass the bumper to meet the headlights this is what you get for a knock off kit |
Jan 12, 2005 - 9:53 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
just shave the inside scoop a lil. i had to do that for the metal bar AND the intercooler. =p
Jan 12, 2005 - 1:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
who did you buy you kit from?
Jan 12, 2005 - 7:28 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
actually, the aluminum crash bar isn't the problem. there are 2 black brackets on the end. Remove those and it'll fit better. But you'll still probably have a gap by the head lights.
Jan 12, 2005 - 11:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
QUOTE(Junior @ Jan 13, 2005 - 12:28 AM) actually, the aluminum crash bar isn't the problem. there are 2 black brackets on the end. Remove those and it'll fit better. But you'll still probably have a gap by the head lights. [right][snapback]232994[/snapback][/right] I had the same problem in the new front end i made. I used a invader top, and it was a cheap copy, both headlights were not equal as far as the fiberglass going to them. I had to add some. I also removed those 2 black brackets. Your not the first, and you wont be the last! |
Jan 12, 2005 - 11:50 PM
are you talking about the brackets ontop of the stock bumper where the 4 bolts go on the top? ya when i did my invader those things didn't fit either.
Jan 14, 2005 - 8:54 AM
Enthusiast ![]() ![]() ![]() Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
whats the big deal about haveing the aluminum bar there in the front?
| Lo-Fi Version | Time is now: September 2nd, 2026 - 8:08 PM |
