> which manifold did you use? 5sfte ppl, 3sgte mani/dp on a 5sfe
post Feb 15, 2005 - 12:02 AM
urbandork
Joined Jul 16, '04
From Los Angeles
What manifold and down pipe would be better to use a 3sgte from a celica or an mr2? i would assume a celica.
But seeing as ill have to run custom exhaust can i just run it off of an mr2 and not worry about the way the down pipe points at its end.
i want to use this
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33742
but its probably for an mr2 even tho it says celica.
ive been thinking about finding a manifold and down pipe that came from a 3sgte that was in a celica but i havnt seen many of those out there. This is why ive been looking at mr2 stuff.
Are the manifold and DP from a celica all track the same as the mr2? i doubt it.
thanks in advanced
post Feb 15, 2005 - 3:54 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
does your car have to have a turbo in order for this to fit? would be nice if i can locally pick it up since hes in the same city as me!!
post Feb 15, 2005 - 9:20 AM
1bwilson
Joined Aug 30, '02
From Maryland
It should work fine. As long as you dont have any problems with the hood hitting.
Member of Team 5sfTe
post Feb 15, 2005 - 11:13 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(LewFX @ Feb 15, 2005 - 8:54 AM)
[right][snapback]246191[/snapback][/right]
yes its an exhaust manifold that fits a turbo between the manifold and the down pipe.
I doubt it will hit the hood so if the price is still right im might use this.
its either that or a stock manifold and dp from a mr2
post Feb 16, 2005 - 4:16 AM
3sgtegts
Joined Dec 10, '04
From Ottawa
Why doesn't it fit into 3rd gen 3SGTE?
post Feb 16, 2005 - 9:04 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(3sgtegts @ Feb 16, 2005 - 2:16 AM)
[right][snapback]246682[/snapback][/right]
The bolt pattern is different on the block.
post Feb 16, 2005 - 11:15 AM
3sgtegts
Joined Dec 10, '04
From Ottawa
Oh ok
thanks
post Feb 16, 2005 - 11:44 AM
shid
Joined Jan 8, '04
From LA
?? it is? So all the manifolds for 3rd gen 3sgtes are different than 2nd gen 3sgtes (and hence the 5sfe) ?
post Feb 16, 2005 - 11:52 AM
1bwilson
Joined Aug 30, '02
From Maryland
As far as I know the 2nd gen is a 6 bolt pattern and the 3rd gen is a 7 bolt pattern. Please people correct me if Im wrong.
post Feb 16, 2005 - 2:58 PM
urbandork
Joined Jul 16, '04
From Los Angeles
cwm13.gif do i have even more to worry about now? some one clear this up.
post Feb 16, 2005 - 3:45 PM
4wheelWOnder
Joined Jan 1, '05
From rapid city, SD
what type of engine do you have agin?
post Feb 16, 2005 - 4:01 PM
shid
Joined Jan 8, '04
From LA
Well, this might sound extremely stupid, but I count 9 bolts on that manifold- which ones count and which ones don't count? Where's the bolt thats different on the 3rd-2nd gen?
post Feb 16, 2005 - 4:29 PM
the problem with that tubular manifold is two fold.
#1 if you dont brace it properly, it WILL crack.
post Feb 16, 2005 - 8:08 PM
urbandork
Joined Jul 16, '04
From Los Angeles
Well i gave that tubular set up thinking few days ago and figured for the cost (even if it was lower then normal) i wouldnt really need it for the power id be running. So i decided to go with the stock mani and stock down pipe.
As such just as long as the turbo matches up with the manifold (twinentry and single entry) then a stock 3sgte manifold no mater the gen should go on to my 5sfe right?
or is there more to the story?
post Feb 24, 2005 - 6:59 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
you gotta chop the upper corner of the manifold to fit it on the head.
post Feb 24, 2005 - 7:38 PM
your gonna wanna stick with a gen 2 mainfold from a mr2 or celica same for the turbo..unless you go for a ct-20b wink.gif or a custom setup..
post Feb 24, 2005 - 11:00 PM
urbandork
Joined Jul 16, '04
From Los Angeles
why not any other generations i take it because of the holes.
anybody got a pic of the two so i can be sure.
This post has been edited by urbandork: Feb 24, 2005 - 11:03 PM
post Feb 24, 2005 - 11:15 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i'm using an mr2 manifold right now and there are like 2 holes i think which are not being used maybe 3. i'll take a pic of it tom for ya
post Feb 25, 2005 - 7:04 AM
the the 165(1st gen)manifold is for a single entry turbo...the 3rd gen manifold is gonna be extremely hard to find. wink.gif
Lo-Fi Version Time is now: August 23rd, 2026 - 10:31 PM
