> 5SFE - Swapping Injectors, remove valve cover or intake?
post Feb 28, 2005 - 11:02 AM
erics1one
Joined Aug 27, '04
From Orange County, CA
I'll be swapping my injectors pretty soon, so been following up on some research.
Question is: 'Can I get to my injectors without removing the valve cover or intake?'
Eventhough I can see the injector wires it doesn't seem like I could, since there isn't a whole lot of room. BOTH the 'Haynes Manual (Celica)' and the BGB (MR2) indicate that the rail can be lifted behind everything.
The only source I've found that states the valve cover needs to be removed is:
http://www.6gc.net/forums/index.php?showtopic=3421&hl=
...and I know Bryan knows his stuff
This post has been edited by erics1one: Feb 28, 2005 - 12:48 PM
post Feb 28, 2005 - 11:06 AM
nik
Joined Sep 30, '02
on the gt i dont think so
i know for a fact on the ST 7AFE you have to remove the TB then the top lead on the manifold to get to the 2 bolts hold the rail down frown.gif i took me about a hour to change my injectors then i had to replace a few seals because there not reusable
This post has been edited by nik: Feb 28, 2005 - 12:36 PM
post Feb 28, 2005 - 12:25 PM
you dont have to take of valve cover, but you may need to move around the harness and what not.
post Feb 28, 2005 - 12:32 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i took mine off to make things easier. its no big deal a few giant nuts and gasket.
post Feb 28, 2005 - 12:47 PM
erics1one
Joined Aug 27, '04
Maybe after removing the strut bar and throttle I'll see a bit more. But this weekend I had a mirror down in there and wasn't feeling to hot about the whole situation.
post Feb 28, 2005 - 2:37 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i never had to remove mine either it was a pain but you just gotta have patience and lil hands to squeeze into those tights places. i shoulda took a pic of my hand n arm after i did the injectors they were all scratched up but eghh. lil tip. disconnect the fuel line from the fuel filter that way you can pull the whole rail out and clean it up. make sure you put new o rings on the injectors.
post Feb 28, 2005 - 5:58 PM
yea...you dont "NEED" to remove it, but it will make the job easier..just drop a couple clean rags over the cams to make sure nothing falls in there.. wink.gif
post Mar 1, 2005 - 10:37 AM
1bwilson
Joined Aug 30, '02
From Maryland
Good luck trying w/o removing. It can be done but the 2 bolts you need to unscrew to remove the rail will be a huge PITA if you leave the valve cover there. Taking the valve cover off is simple, 4 big nuts and a thump of the rubber mallet and its off.
Member of Team 5sfTe
post Mar 1, 2005 - 5:47 PM
Fox-N-It2
Joined Jul 24, '04
From Va
After rebuilding my friends 5s we had trouble with the O rings sealing. It is possible to do it with the intake and valve cover on you just got to be patient.
post Mar 1, 2005 - 6:11 PM
macavely
Joined Nov 4, '02
if u guys want to do this right hit me up and u can DL the sevrice manule from me..
post Mar 7, 2005 - 12:06 AM
erics1one
Joined Aug 27, '04
Well its done.
Didn't have to remove the valve cover. The biggest thing that was in the way was the wiring harness. If that thing wasn't there it would have been a one hour job.
Lo-Fi Version Time is now: June 24th, 2026 - 12:02 AM
