> Rubber trim around headlights, Its falling off, what can I do
post Mar 3, 2005 - 10:11 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Hi,
I was just wondering what I could do about my headlights.
There is a black rubber trim that goes around all of them, and they seem to be coming off.. Would ordering replacement trim fix this??
The trim does not appear to be broken, its just loose so I always push it back in a bit...
Thanks,
Rob
post Mar 3, 2005 - 10:17 PM
ghostdog
From ny to philly
they just do that. if it really bothers you, you can take off your front bumper and adjust the clips that hold it on. although they will eventually come loose again anyway wink.gif
post Mar 3, 2005 - 10:20 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
or superglue them and forget about it.
Team 6gc 2005
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Drocay @ Mar 3, 2005 - 10:20 PM)
[right][snapback]252961[/snapback][/right]
Until you have to replace a headlight.
post Mar 3, 2005 - 10:23 PM
you talking about the rubber around the headlight? mine started coming off too, used super glue and it worked perfectly.
post Mar 3, 2005 - 10:27 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Thanks guys that was fast .. Um I'm not sure if I want to superglue it.. What if I replace the headlight like jgreening said... Will I have to order a new one? (the rubber piecet that is..)
I'm glad to know that it's a common problem, I thought it was maybe cause my cars 11 years old..
-Rob
This post has been edited by RbrtNdrws: Mar 3, 2005 - 10:29 PM
post Mar 3, 2005 - 10:30 PM
Mynzeyes
From Franklin/Nashville, TN
superglue it. on the RARE event that you need a new headlight (which is very unlikely unless you are in a wreck, in which case you'll probably need a new seal anyway...), the trim is only 8 bucks. i had to order some for my high-beams not long ago.
-John-
AIM==Mynzeyes
post Mar 3, 2005 - 10:50 PM
CelicaBuddy
Joined Nov 1, '04
same thing is going on with me...
but its only my one rubber thing... My other one fell off
I needs to get more
1995 Convertible Celica
2003 Nissan Murano SE
post Mar 4, 2005 - 12:10 AM
pr_caralho
Joined Jan 24, '05
From toronto,ontario canada
Happened to me to, i just carefully put it back and did what the other ppl did
Go leafs go
post Mar 4, 2005 - 12:45 AM
popstar
Joined Nov 24, '04
From Moscow, russia
i used a rubberized glue......
holds it in place, but you can get the rubber rings off if ever you want with a sharp blade !!!!!
Life is for living, and you don't get a second chance
Take care now !!
post Mar 4, 2005 - 1:26 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Nope, they will remove easily if you use superglue, i useed it, and still removed myne easy (ruber surounding) Superglue wount stick to glass too hard, but it will help to hold the surounding in place.
QUOTE(jgreening @ Mar 3, 2005 - 8:20 PM)
[right][snapback]252963[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Mar 4, 2005 - 2:57 AM
Benevolence
Joined Oct 9, '02
From San Diego, CA
heh am I the only one that just ripped mine off when they started coming loose? I think they look good w/o them... well I still have the two inner ones on just not the two outer headlights (low beams)
post Mar 4, 2005 - 3:55 AM
Insanity-74
Joined Jan 9, '05
From Under the car
Just leave them off, I dont have any on my`n, looks cleaner without them.
post Mar 4, 2005 - 4:53 AM
QUOTE(Benevolence @ Mar 3, 2005 - 11:57 PM)
[right][snapback]253100[/snapback][/right]
Amy(amysmojo) also doesn't have them on her car.
I glued mine on using spray on 3M glue, and it's worked perfectly for me.
post Mar 4, 2005 - 8:38 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
goop glue
post Mar 4, 2005 - 9:46 AM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
i have the same problem...
post Mar 4, 2005 - 1:07 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
rubber glue gun biggrin.gif thats what i used and it hasnt popped up to bother me since
post Mar 4, 2005 - 2:29 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
if your missing the metal clip that holds the ring in place just get a flexible piece of metal and bend it in the same way and it holds it in place, well at least for me smile.gif
post Mar 4, 2005 - 3:34 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
thanks guys, I'll try supergluing it..
Also, Coomer I sent you a PM but I dont know if you received it.. I had a question about something.
-Rob
post Mar 4, 2005 - 3:44 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Mine come loose every so offten, every time i park and notice ther coming out, i just tell them whos boss and push them back in.. wink.gif lmao.. its true..
Lo-Fi Version Time is now: September 10th, 2026 - 6:23 PM
