Mar 21, 2005 - 5:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
Well ive been running frams, being the fact they are easy to get your hands on. Recently I have been hearing these are horrible oil filters... whats a good brand? Ive heared amazing reviews of purolator filters but I cant find them anywhere! Does anyone know of a good online resaler for oil and filters?
Mar 21, 2005 - 5:21 PM
I always use Toyota OEM filters...they're really good. I hear that Amsoil and Mobil 1 are even better though...I plan to make the switch to those if they're not too pricey.
Mar 21, 2005 - 9:19 PM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
I use Mobil1 oil filter. I like it, because it seems to free up some horsepower.. But it could be just my mind playing tricks on me. I heard that castrol oil filters will put bad films on the engine internals though.. I used K&N filters before.. But I don't know which one to use on the 6GC's..
This post has been edited by Newbie: Mar 21, 2005 - 9:20 PM |
Mar 21, 2005 - 9:55 PM
QUOTE(Newbie @ Mar 21, 2005 - 9:19 PM) I use Mobil1 oil filter. I like it, because it seems to free up some horsepower.. But it could be just my mind playing tricks on me. I heard that castrol oil filters will put bad films on the engine internals though.. I used K&N filters before.. But I don't know which one to use on the 6GC's.. [right][snapback]260432[/snapback][/right] its in your head if you really want to decide what filter to use, cut the used filter open and look inside... then put a mobil filter in and cut that open after you are done with it, then compare the 2. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 21, 2005 - 10:10 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
ive been using mobil products (10w-30 mobile 1 with the mobile 1 filter), but due to personal oiling issues and from alot of first hand accounts from other friends, im going to try switching it all over to amsoil after my next oil change.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 21, 2005 - 10:39 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
What's bad about Fram? I use Fram too mainly because of that black grip.
Mar 21, 2005 - 10:43 PM
fram lacks the drain plug like other filters have. when you shut your car off the oil is suppose to stay in filter to keep some oil ready for start up. fram filters lack that and hard on engines because of it. "from what a mechanic told me"...he suggest purolaters or napa
Mar 21, 2005 - 10:49 PM
Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
I'm not a believer of the hype. I bought my celica with 100,000 miles on it and I've put another 150k on it myself and all I've used are Frams. I just change them every 3,000.
Mar 22, 2005 - 4:33 AM
Enthusiast ![]() ![]() Joined Aug 19, '04 From Berkeley Currently Offline Reputation: 0 (0%) |
walmart supertech filters are very good for the price. a lot of information is at the bobistheoilguy forums.
Mar 22, 2005 - 8:22 AM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
I use fram for the grip thingy and I also use Stp is that any good. Recently I'm using toyota filter
Mar 22, 2005 - 7:52 PM
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
I use the TRD oil filter one from a toyota dealer
they work great no problems |
Mar 22, 2005 - 8:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
wut about K&N filters, there like 12 bucks but should be qualtiy.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Mar 22, 2005 - 8:36 PM
QUOTE(94GT @ Mar 21, 2005 - 10:49 PM) I'm not a believer of the hype. I bought my celica with 100,000 miles on it and I've put another 150k on it myself and all I've used are Frams. I just change them every 3,000. [right][snapback]260459[/snapback][/right] I have done the same.. not as mnay miles. But I have been useing Fram.. never had a problem with them. Also cant see spending $13 on a k&n one. I also change my oil every 2500 miles, cause i dont drive much. I think im going to try the mobil1 next time just cause thats the oil i tend to use. |
Mar 22, 2005 - 8:46 PM
i use mobil 1 synthetic and i change every 5k just cause i should be able to get out of it that much condsider my car doesnt eat none of my oil, so the 12 bucks aint that bad.
Mar 22, 2005 - 8:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
I too, like coomer use the toyota filters. They are often even cheaper then frams if you check out a few of your local dealers. I have seen them as cheap as $3.50.
It would be more efective to use 2 or 3 toyota or fram filters instead of one K&N. And yes you can change just the filter... Also TRD oil filters are supost to be some of the best, but $20+ for an oil filter is insane unless your running a true "high performance machine" |
Mar 22, 2005 - 9:58 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Wix, its all about the Wix filters.
The best low priced filter there is. DEF -------------------- ![]() I will return one day. |
Mar 23, 2005 - 12:25 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
yep fram are junk and wix are best bank for the buck napa filters are the same thing
Mar 23, 2005 - 12:59 AM
how are you guys comparing whats better? has anyone here cut their filter open? the cheap ones i cut open are just carboard inside...
Mar 24, 2005 - 4:41 AM
Well i get my TRD ones for 12 buxx at my local toyota dealer
i just have to wait a week for them to order it |
Mar 24, 2005 - 8:24 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
I think I have a Blitz filter. Seems OK.
-------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
| Lo-Fi Version | Time is now: May 30th, 2026 - 2:49 AM |
