Mar 31, 2005 - 12:18 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
leaving work today.. clutch feels funny, can't really explain, then, i get to a stop sign, and i put it in first, start lettin go of the clutch... realize that my pedal stayed on the floor, it didn't come back up with my foot. so i turn off my car, LEAVE it there... (wasn't too happy about that) go to work, call my boyfriend.. he comes, we push my car onto the parking lot, he pulls my pedal back up, starts it, drives it around a bit, says it feels fine. so he drives it home, then we check it out, and my shifter (when i move it around) has a lot more play, and makes like, clicking noises, as if there's a loose metal piece moving around when i move my shifter around. so we're thinking these things: release bearing, clutch linkage (if there's such?), shifter linkages, pressure plate, fluids.... someone must know! people are smart here... thanks guys!
Mar 31, 2005 - 12:23 AM
imo
its shop time i need a new clutch too! |
Mar 31, 2005 - 12:38 AM
thing is, i have a stage one clutch in there... hasn't even been in my car for a year, maybe like, 7 months?
Mar 31, 2005 - 3:41 AM
Enthusiast ![]() Joined May 7, '04 From Leeuwarden, Netherlands Currently Offline Reputation: 0 (0%) |
Maybe gearbox oil needs to be refresht. If the car didn't drive for such a long time, the oil gets sticky. Try that first before you do other (expensive) repairs.
Check clutch fluid also, you have a hydraulic clutch. Maybe there's too much moist in it. (brown color) Or there's nothing left at all. This post has been edited by Silvan: Mar 31, 2005 - 3:45 AM |
Mar 31, 2005 - 9:09 AM
Enthusiast ![]() Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) |
check the clutch master cylinder, see if it has fluid and try bleeding the air out of it. it may have a bad master cylinder or slave cylinder or a leak inbetween the two. the noise you ar hearing in the gear box is probably because the clutch is not releasing completly, i would bleed the system first and see what happens. as for the play in the shifter i inspect the shifter cables and linkage and make sure nothings loose.
Mar 31, 2005 - 11:31 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
QUOTE(Silvan @ Mar 31, 2005 - 8:41 AM) Maybe gearbox oil needs to be refresht. If the car didn't drive for such a long time, the oil gets sticky. Try that first before you do other (expensive) repairs. Check clutch fluid also, you have a hydraulic clutch. Maybe there's too much moist in it. (brown color) Or there's nothing left at all. [right][snapback]264586[/snapback][/right] This has absolutly nothing to do with the clutch, it is more than likely the slave cylinder, clutch master cylinder, low clutch fluid, or needs bleeding. |
Mar 31, 2005 - 12:03 PM
Enthusiast Joined Mar 31, '05 From Northern England. Currently Offline Reputation: 0 (0%) |
slave cylinder, i had this last year.
-------------------- see my gallery at http://www.gt4oc.net/owners/owners_page.php?owner=2938
90 GT4 JDM 270bhp 89 GT4 UK Carlos Sainz Engine and Tranny - project 87 GT Convertible, 3SGE powered with nitrous, 205bhp. |
Mar 31, 2005 - 12:44 PM
slave cylinder was the first thing my boyfriend thought it was... how much would that cost me?
Mar 31, 2005 - 2:22 PM
If you install it $20 or $30 bucks. It is easy to do should take like 30 mins.
Mar 31, 2005 - 6:08 PM
yeah i am doing it by myself, i just wanted to know the price of the part, thanks a bunch.
Apr 3, 2005 - 11:56 PM
Enthusiast ![]() Joined Mar 11, '03 From Springfield, Ohio Currently Offline Reputation: 0 (0%) |
that is kinda the same problem that i am experiencing. would this problem also cause the clutch to slip somethmes in some of the higher gears?
Apr 6, 2005 - 4:10 AM
QUOTE(Rjb23 @ Mar 31, 2005 - 4:31 PM) QUOTE(Silvan @ Mar 31, 2005 - 8:41 AM) Maybe gearbox oil needs to be refresht. If the car didn't drive for such a long time, the oil gets sticky. Try that first before you do other (expensive) repairs. Check clutch fluid also, you have a hydraulic clutch. Maybe there's too much moist in it. (brown color) Or there's nothing left at all. [right][snapback]264586[/snapback][/right] This has absolutly nothing to do with the clutch, it is more than likely the slave cylinder, clutch master cylinder, low clutch fluid, or needs bleeding. [right][snapback]264627[/snapback][/right] My bad, I didn't read too well, you are totally right. But like I said, clutch fluid. or else slave cilinder indeed. @gt2nv: I would say its the pressureplate. |
| Lo-Fi Version | Time is now: June 12th, 2026 - 7:55 PM |
