Apr 4, 2005 - 6:54 PM
Enthusiast ![]() Joined May 14, '04 From Port Arthur. TX. Currently Offline Reputation: 1 (100%) |
I have tried "SEARCH", but I have a 3sgte flywheel and clutch and a 93 gt tranny. The only problem I'am having is the 3sgte pressure plate is bigger than the gt tranny splin. I tried getting the gt pressure but it is 8 1/2 inches in diameter and the 3sgte is 9 1/4. Would this be okay? I also find out that MR2 pressure plate is 9 1/4 but I don't know if the splin is the same as the 3sgte or gt tranny. Thanx.
Apr 4, 2005 - 7:08 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
edit what am i thinking. you need the 5sfe clutch w/ a 3sgte pp
DEF This post has been edited by defgeph: Apr 4, 2005 - 7:09 PM -------------------- ![]() I will return one day. |
Apr 4, 2005 - 7:15 PM
The 3sgte PP splin is bigger than the gt tranny splin. You know the thing that sticks out (inside the tranny) and fits to the PP.
Apr 4, 2005 - 8:41 PM
what are you going to use this for.... are you doing a swap and using a 5sfe tranny?
if so, you need a 3sgte pressure plate,3sgte flywheel, with a 5sfe clutch and 5sfe throwout bearing. the clutch disk will be a little smaller, but this wont cause any problems. if you want the clutch disk to be the correct size, you can call up Spec or Clutchmasters and tell them to make you a custom 3sgte disk with the 5sfe splines. thats what i did for my spec stage 3 clutch. This post has been edited by lagos: Apr 4, 2005 - 8:43 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
| Lo-Fi Version | Time is now: September 2nd, 2026 - 3:28 AM |
