> Turbo, Turboooo
post Apr 14, 2005 - 9:14 PM
Celica_Kid95st
Joined Feb 24, '05
From Pittsburgh, PA
Whats up guys. Ok my friend is selling a turbo for like $100. I have a '95 ST, and not alot of money, but this kid i no said that u can still put it on without an intercooler and pipes and **** for now at least but not to wait like years u no. I'm wondering if hes right and i can just buy the turbo and weld it on. Is that right? If so what other things would i have to get right now, but i want the littest that i can cause i dont have like any money, like if i dont need it now then skip it. Aight thanks for the help. peace. -john
post Apr 14, 2005 - 9:38 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
all u would need is the exhaust manifold, turbo, piping from turbo to intake manifold, piping for intake some vacume lines a fuel pressure regulator....think thats about it.$100 seems pretty cheap tho.
post Apr 14, 2005 - 9:49 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
QUOTE(Celica_Kid95st @ Apr 15, 2005 - 2:14 AM)
[right][snapback]271609[/snapback][/right]
johnny my friend u have no idea what ur getting yourself into, lol
Now SR powered
post Apr 14, 2005 - 9:53 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
with the way a turbo fits in the celica engine bay, its easier and needs less piping to just install a FMIC from the get go.
get a $200 ebay intercooler, then a $150 greddy universal piping kit.
manifold is gonna be around $300 assembled, if i remember correctly
then you need oil lines
um, atleast an FMU and DEFINATELY A FUEL PUMP
and a down pipe
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Apr 14, 2005 - 10:15 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
does the turbo have a wastegate?
post Apr 15, 2005 - 1:41 AM
ummmx2
Joined Nov 6, '04
dont forget injectors and bov
post Apr 15, 2005 - 6:48 AM
OrbitalGT95
Joined May 3, '04
From pittsburgh
see what i mean john, lol...my wallet is afraid of turbo's
Now SR powered
post Apr 15, 2005 - 9:08 AM
nik
Joined Sep 30, '02
i can give you a list of everything you need plus look at my how to it will show you step by step amostly how to turbo your st
post Apr 15, 2005 - 10:38 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
You don't need a new fuel pump, or new injectors. All you need is the equipment to put it on there. So yes, it would be similar to just welding it on. I'd recommend definitely an intercooler. Exhaust manifold and down pipe are going to be necessary. You might get the down pipe custom. The exhaust manifold will be easy to find though. You'll need a waste gate for controlling boost levels too. If you end up running into problems, then add things like fuel pump and injectors. If you run low boost, you should be fine.
Hey guys, please stop trying to scare off new people from doing these things. The best way to learn is to just do it. Not to say that telling these guys how to do it is bad, but telling them that it's a nightmare and they have no idea what they're getting into is. Just tell them how it is, don't make assumptions about they're mechanical abilities.
EDIT: This post really isn't to bad about blowing things out of proportion. I must have been thinking of other posts in combination when I wrote this. Things blend together sometimes when I read.
This post has been edited by Bigmeanbulldog55: Apr 15, 2005 - 10:39 AM
Live Free, Be Happy
post Apr 15, 2005 - 10:41 AM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
big- you do need a new fuel pump... just like running the celica gt fuel pump on the 3sgte it will work for a lil while but it will blow a piston up by running lean inthe high end...
-DMC
post Apr 15, 2005 - 10:47 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I just had a buddy of mine who put a supercharger on a 3.8 chevy, and he keep it all the same. After I started writing this, I remembered the car was supercharged, and he just put the s/c on a new 3.8. He probably used the s/c fuel pump. My bad. But I don't see how running low boost would be any different from running a ram(forced) air intake. That's what I have, do I need a new fuel pump?
On a side note, I really wish they wouldn't call those short intakes "ram air intakes," it's extreemly misleading. And when someone has an actual ram air intake, they have to say forced air, but clarify that it's not a turbo or supercharger.
Live Free, Be Happy
post Apr 15, 2005 - 11:07 AM
ummmx2
Joined Nov 6, '04
air intakes are MUCH different than forced induction. because of the fact that intakes dont actually force ne thing into the motor, rather it just helps it to breathe. btw, just "doing it" with minimum parts is a recipe for a blown motor. look at niks list and the 7afte bible. you will need to upgrade your fuel system at least or else you will run lean and damage something.
post Apr 15, 2005 - 11:14 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(ummmx2 @ Apr 15, 2005 - 12:07 PM)
[right][snapback]271859[/snapback][/right]
See? This is exactly what I'm talking about. It's hard for people to understand what I'm saying.
Live Free, Be Happy
post Apr 15, 2005 - 12:11 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
QUOTE(Bigmeanbulldog55 @ Apr 15, 2005 - 7:47 AM)
[right][snapback]271853[/snapback][/right]
a "ram" intake still will not "force" air into the engine like a turbo will it pretty much puts the car from a vacuum state to a nuetral state... not give boost thoug... well MAYBE one or 2 psi...
-DMC
post Apr 15, 2005 - 1:00 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(thedevilmaycrie @ Apr 15, 2005 - 1:11 PM)
-DMC
[right][snapback]271883[/snapback][/right]
So even though I have a scoop in my front bumper that appears to force air in, it's not? What if it was a BIG scoop? I do get what you’re saying though. Without the turbo or s/c there, there's nothing to really force the air in, and it only makes it equal instead of forcing air in. That's pretty much what you said, I think. I've always been kind of worried about using it on the interstate, I thought it'd force to much air in and blow it up. My dad told me that you can't force to much air in, but my uncle said you could. My uncle is usually smarter when it comes to the mechanics of cars. The scoop I have now is the size of the 94-95 hole in the bumper on the side. There was kind of a scoop thing there in the first place, on the right looking at the car. But I sealed it and ran tubing from it to my throttle body. There's a filter in there sometimes wink.gif . I always thought that around 30mph I would have the same boost as a lot of turbos. What's the verdict on my situation here?
EDIT: Sorry about the failed attempts are editing this thing right. And I really think this belongs in a new post, sorry about cluttering up your "turbo" post there buddy.
This post has been edited by Bigmeanbulldog55: Apr 15, 2005 - 1:07 PM
Live Free, Be Happy
post Apr 15, 2005 - 1:16 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
QUOTE(Bigmeanbulldog55 @ Apr 15, 2005 - 11:00 AM)
-DMC
[right][snapback]271895[/snapback][/right]
Snapback, there is absolutely no way that you are getting any sort of forced air into your engine. You have nowhere near equallity to a turbo... my guess is that you havn't really experience a car with a turbo in it. If you have forgive me... but if you havnt find someone with one and let them take you for a ride! All that scoop does is get cold air from outside instead of warm air from the engine bay. The only way you can get "too much air" is by using forced induction.
post Apr 15, 2005 - 2:26 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
doge- the scoop may not equal or come close to a turbo but it will equalize the vac/boost...
big- even if the scoop was your front end it wouldnt eqaul boost... if you wanna see for yourself take a boost/vac gauge in your car ans see what it does and if it will even equal out the boost/vac...
-DMC
post Apr 15, 2005 - 2:31 PM
nik
Joined Sep 30, '02
i'll put it into simple terms your motor will only let so much air in no matter how big a scoop you have thats why turbo cars are called force induction your forcing air into the motor to make power.
any questions?
post Apr 15, 2005 - 5:51 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(thedevilmaycrie @ Apr 15, 2005 - 3:26 PM)
-DMC
[right][snapback]271941[/snapback][/right]
I thought I might equal the boost of a small turbo or supercharger. You know, like 1-3 pounds of boost. I just might try that boost/vac gauge for the heck of it. The hole thing just doesn't sound completely clear and rgiht to me. I feel like there's more to this story somewere. I'm not saying in any way that I don't believe you. I just want to know exactly how much boost/vac I'm running with this thing.
Live Free, Be Happy
post Apr 15, 2005 - 5:55 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
big- by all means please try it and let us know the results...
-DMC
Lo-Fi Version Time is now: September 15th, 2026 - 12:07 PM
