Apr 18, 2005 - 9:57 PM
Enthusiast ![]() ![]() Joined Apr 14, '05 From garfield hts. O-HI-O Currently Offline Reputation: 0 (0%) |
yeah thats what im dooing just hooking it up to a amp. now i only have 6.5 nch speakers and some 5x7 or 6x8's is there any way in hell i can mouth these in there?? lol and in my old car there were 2 clips inder the rear seat that lifted the cushion up, cant the cushon come up in the celica?? i usualy run the wires under the carpet or trim piece then under the back seat into the trunk. is there any other way to do this thats easyer?? i need to get the power wire on 1 side of the car and the rca's on the other
Apr 18, 2005 - 10:59 PM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
i ran all my rca's and remotes down the center consol, under the armrest, under the carpet, under the seat, and to the trunk. the power wire i ran down the left side of the car to the distributor block under the rear seat, then the 2 seperate power wires from there to my trunk. both amps mounted to back of seats with wires not visable (wires ran under amps, then through the seat material, and down to the rear seat). hope this helps out any.
Apr 19, 2005 - 7:15 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
![]() There is a plastic piece you pry up here under the plastic foot strip you can run the 4 gauge wires down this side. ![]() *thats down the side you have to take off rear panel to get power wire into trunk*![]() Good luck! its not hard! Run the Rca's same way down the other side! This post has been edited by slipgun: Apr 19, 2005 - 7:19 PM |
| Lo-Fi Version | Time is now: August 30th, 2026 - 7:26 PM |
