> 5SFE M.A.P Sensor, camry sensor vs. celica
post Apr 23, 2005 - 10:30 AM
GTcrazy
Joined Apr 23, '05
Does anyone know whether the camry 5SFE MAP sensor works for the 5SFE celica sensor? they both have the same engine i would think. but when comparing both parts together they are different in shape and size, though the connection fits. I don't know much about the voltage specs on them, just wondering if anyone has ever tried the camry map sensor in their celica's. (Both cars were 96 models. )
I did however contacted a local dealership and they stated that it will not work.
post Apr 23, 2005 - 6:27 PM
TTE
Joined May 19, '03
From NJ
It sends signal in volts to ECU how much fuel to put into engine. If two engines are identical they should be using same fuel maps. I think it should work.
post Apr 25, 2005 - 7:24 PM
GTcrazy
Joined Apr 23, '05
QUOTE(TTE @ Apr 23, 2005 - 5:27 PM)
[right][snapback]276942[/snapback][/right]
Thanks for the info.
Lo-Fi Version Time is now: August 25th, 2026 - 2:45 AM
