Apr 25, 2005 - 6:41 PM
Enthusiast ![]() ![]() Joined Jan 5, '05 From Upper Darby, PA(5 min away from Philly) Currently Offline Reputation: 3 (100%) |
How much do you guys think it would cost to have a 95 Celica ST engine rebuilt?Im thinking about having it done. My Celica engine has 189,000 miles on it and it has most alot of its power.
Apr 25, 2005 - 7:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
Rebuild kit itself is 350-400 labor is gona be the bitch.
Apr 25, 2005 - 8:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
QUOTE(Drew-887 @ Apr 25, 2005 - 3:41 PM) How much do you guys think it would cost to have a 95 Celica ST engine rebuilt?Im thinking about having it done. My Celica engine has 189,000 miles on it and it has most alot of its power. [right][snapback]277932[/snapback][/right] im sure you can find a used 7afe wiht low miles for cheap. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Apr 25, 2005 - 9:17 PM
![]() Enthusiast ![]() Joined Apr 18, '05 From Atlanta, Georgia Currently Offline Reputation: 0 (0%) |
Or you could try to swap in a 5sfe?? It would probably be the same price as a total rebuild, plus youd get more power.
This post has been edited by JoeyIsFunny: Apr 25, 2005 - 9:18 PM |
Apr 25, 2005 - 9:22 PM
that would be a totally WORTHLESS SWAP
for the same money effort as a 5sfe you could just do a 3sgte dear lord the wacky info around here to rebuild a 7afe requires a great deal of work as with any motor i think my friend just got his rebuilt for around 1k or so |
Apr 25, 2005 - 10:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
QUOTE(Drew-887 @ Apr 25, 2005 - 4:41 PM) How much do you guys think it would cost to have a 95 Celica ST engine rebuilt?Im thinking about having it done. My Celica engine has 189,000 miles on it and it has most alot of its power. [right][snapback]277932[/snapback][/right] where do you find these rebuild kits This post has been edited by rlan214: Apr 25, 2005 - 10:20 PM -------------------- |
Apr 25, 2005 - 10:27 PM
If you do it your self some what cheap, if you have a shop do it, around $1200 then they'll throw in a bunch of BS and prolly get to $1500+ .. Id say just look for a low milage 7a-fe.. then just swap it out.
Apr 25, 2005 - 10:57 PM
QUOTE(playr158 @ Apr 25, 2005 - 9:22 PM) that would be a totally WORTHLESS SWAP for the same money effort as a 5sfe you could just do a 3sgte dear lord the wacky info around here to rebuild a 7afe requires a great deal of work as with any motor i think my friend just got his rebuilt for around 1k or so [right][snapback]277997[/snapback][/right] Would it really cost the same as a 3sgte?? I honestly didnt know that.. crazy. Is the 5sfe really that expensive?? You could just yank one out of a junk yard car and clean it up. |
Apr 26, 2005 - 1:43 AM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
A good rebuild will cost you ~1k if you do it your self and have tools,
To include: Rings, all crank/cam seals, water pump, timing belt tensioner, head gasket, getting the head milled and new valve seals at machine shop, exhaust gaskets, getting flywheel resurfaced, new clutch, all of those stupid gaskets on the intake, plugs, wires, and belts. Dont' forget just getting lithium grease, loctite, pb blaster, gasket material, brake cleaner, antisieze, oil, brake fluid (for clutch), antifreeze, cotter pins, those stupid pins that hold the drive shafts in, and shim can run a few hundred dollars. That's if you don't break any bolts too. |
Apr 26, 2005 - 2:07 AM
Enthusiast ![]() Joined Feb 7, '05 From Fresno, CA Currently Offline Reputation: 0 (0%) |
If it costs so much to rebuild why not just modify and end up with more performance gain than you will get by just rebuilding.
Apr 26, 2005 - 8:19 AM
Enthusiast ![]() ![]() Joined Feb 16, '05 From south carolina Currently Offline Reputation: 0 (0%) |
yea id def just get a new engine.. if i couldnt find a 3sgte for reasonable price, id settle for a 5sfe.
Apr 26, 2005 - 6:13 PM
Yeah, just swapping my engine does sound like a good idea. I want a 5sfe engine but I have no idea how much it will cost or where I could buy one. Could someone give me prices and places where I can find 7afe and
5sfe engines? |
Apr 26, 2005 - 7:31 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
as playr said, why would you do a 5sfe swap which would give you very little power, as opposed to a 3s-gte swap which would give you ALOT more power... and its only gonna cost a bit more.
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Apr 26, 2005 - 7:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
take it easy man, the guy is new. besides I don't see you always giving correct info either
rather than a 5sfe swap, a more cost effective solution would be an A-series engine. this way you wouldn't have to change the mounts or transmission. a 4age, 4age 20v or 4agze would all be great options depending on how much money you have to spend QUOTE(playr158 @ Apr 25, 2005 - 10:22 PM) that would be a totally WORTHLESS SWAP for the same money effort as a 5sfe you could just do a 3sgte dear lord the wacky info around here [right][snapback]277997[/snapback][/right] |
Apr 26, 2005 - 10:54 PM
Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
anyone who swaps out a 7afe for a 5sfe is a pure idiot...first of all 5sfe is 2.2liters which means it burns more gas than a 2 liter 3ste and it only put out what 135hp? so hp per liter sucks ....7afe is way more efficient considering it does 115hp 1.8l....if ur gonna switch to an s series drivetrain go with 3sge if u cant afford the 3sgte...3sge will give u at least 170hp and kills 5sfe
Apr 26, 2005 - 10:57 PM
Hey guys look all I wanted to do was try to new engine. I'm not try to do do a big swap. I dont have that kind of money. My engine now has alot of miles on it so i want a new one. I think I might take advise from gh0st_d0g and get a A-series engine. I would still like to know how much the 5sfe would cost just in case I dont have the an A-series.
Apr 27, 2005 - 1:16 AM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From NJ Currently Offline Reputation: 1 (100%) |
talk to bboyrugged and see how much he wants for his cuz he's doing a swap. it only has like 70k on it i think.
Apr 27, 2005 - 9:44 AM
Enthusiast ![]() Joined Apr 18, '05 From Temecula, CA Currently Offline Reputation: 0 (0%) |
hello drew...
im thinking about putting a new engine in my car also.. in the next couple months... if your willing to spend around 450 - 750 dollars... u could get a 3sge engine with 145 - 170 hp (depending on block head) .. the 3sgte would cost uy about a grand more but will give u 240 hp.. heres a link where u could buy them.. http://www.toysport.com/catalog/PET%203S-G...0Conversion.htm as for the a seris engine.. i dont know where u could get those... but i hope this helps! |
Apr 27, 2005 - 2:04 PM
QUOTE(audioOutput @ Apr 27, 2005 - 9:44 AM) hello drew... im thinking about putting a new engine in my car also.. in the next couple months... if your willing to spend around 450 - 750 dollars... u could get a 3sge engine with 145 - 170 hp (depending on block head) .. the 3sgte would cost uy about a grand more but will give u 240 hp.. heres a link where u could buy them.. http://www.toysport.com/catalog/PET%203S-G...0Conversion.htm as for the a seris engine.. i dont know where u could get those... but i hope this helps! [right][snapback]278791[/snapback][/right] How much does it cost to have a shop do the swap for you?? Im guessing upwards of $1,000 in labor costs? |
Apr 27, 2005 - 2:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 4, '03 From Kirkland, Washington Currently Offline Reputation: 0 (0%) |
im getting a 5sfe and building it up. You can get one of those for cheap like a dime a dozen!
250 - 600 bucks depending on how many miles are on it i bet is what ur looking to pay for a 5sfe This post has been edited by BlackCelicaGT94: Apr 27, 2005 - 2:14 PM -------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
| Lo-Fi Version | Time is now: August 24th, 2026 - 9:44 PM |
