Apr 27, 2005 - 6:45 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Ok so I decided to do my 3sgte swap myself, me question is I want to get an extra engine harness from a 95 st or 95 gt and get the harness done so I can still drive my car while I get everything ready. Anyway my question is does it matter if I get the same year and model harness? I have a 95 st so if I get a gt harness will it make a huge difference?
Apr 27, 2005 - 8:13 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
umm if you have an st then get an st harness. buying a gt harness will get you nowhere. you wont even be driving anywhere let alone plugging your harness into it.
so to answer your question. buy a 94-95 ecu. if all else just get any st ecu. -------------------- hows it taste motha f*cka |
Apr 27, 2005 - 8:45 PM
Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
spend 1000 bucks for a universal haltech standalone ecu
Apr 27, 2005 - 8:55 PM
or spend 50 bucks for an extra ecu that you could resell online.
Apr 27, 2005 - 9:41 PM
QUOTE(Sev408 @ Apr 28, 2005 - 1:13 AM) umm if you have an st then get an st harness. buying a gt harness will get you nowhere. you wont even be driving anywhere let alone plugging your harness into it. so to answer your question. buy a 94-95 ecu. if all else just get any st ecu. [right][snapback]279133[/snapback][/right] OK uhmmm, an st ecu will get me no where I don't want an ecu I have 2 of them. And for one they will not work with a 3sgte. I have a front clip. I want an extra harness so I can take the extra one and the 3s harness and get the harness made for the swap, and I can drive my car while it gets done. And I dont want a standalone, when the 3s ecu will work perfectly fine. |
Apr 28, 2005 - 11:46 AM
Anyone?
Apr 28, 2005 - 12:10 PM
yes, you can do that.
dont wase your money on it tho. you will have a few weeks downtime when do a swap, there is just no way around it. when i did my swap, i started working on the clip 1st, pulling out the 3s, cleaning stuff up, etc. then when all that was done, i pulled my car in last to minimize downtime. even still, i didnt have a running car for about a month. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 28, 2005 - 12:43 PM
QUOTE(lagos @ Apr 28, 2005 - 5:10 PM) yes, you can do that. dont wase your money on it tho. you will have a few weeks downtime when do a swap, there is just no way around it. when i did my swap, i started working on the clip 1st, pulling out the 3s, cleaning stuff up, etc. then when all that was done, i pulled my car in last to minimize downtime. even still, i didnt have a running car for about a month. [right][snapback]279534[/snapback][/right] Thanks, Lagos. What kind of problems did you run into that kept it from running? |
| Lo-Fi Version | Time is now: August 25th, 2026 - 7:41 PM |
