> gran turismo lol, dont make fun :D
post May 19, 2005 - 7:56 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
on gt3, for na tunup stage 1 on a ST202 celica it says: "Boosts the power on non-supercharged engines by adjusting the ignition and valve timing and installing thinner head gaskets for higher compression ratio. The exhaust manifold is also replaced. Peak power is enhanced without affecting low-rpm torque." can i do this on my at200 without getting the header? ive never seen this brought up before so i was just wondering if a 7afe could get some power this way.
post May 19, 2005 - 8:15 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Sure... but its not gona be cheap.
post May 19, 2005 - 8:17 PM
Hanyo
Joined Aug 16, '03
From Bay area
your not gonna see as much gains as a performance motor..
the flow design of the 7afe is just not good.. so no matter how you tune it.. it will not give you good power.
post May 19, 2005 - 8:20 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
why dont you keep saving your "credits" and buy a suzuki escudo?
To live, is to suffer
post May 19, 2005 - 8:23 PM
rocky2006
Joined Aug 18, '04
well the only thing that would cost money is the gaskets. i guess it's not worthwhile on the lil 7afe. thanks for the replies.
post May 19, 2005 - 9:28 PM
post May 19, 2005 - 9:41 PM
Hanyo
Joined Aug 16, '03
From Bay area
i always wanted to do a high compression engine like edo's car..
post May 20, 2005 - 1:36 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Header is where the most hp is at from the things you listed.
post May 21, 2005 - 3:08 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
Did we ever get the numbers on edo's na 7afe?
post May 21, 2005 - 11:46 AM
macavely
Joined Nov 4, '02
do it ..... and silence the unbelivers...
post May 21, 2005 - 1:39 PM
edo17982
Joined Dec 21, '02
From Italy
QUOTE(94ST2 @ May 21, 2005 - 10:08 AM)
[right][snapback]289894[/snapback][/right]
Yes, Doggy will get my emanage tuned in few days and then we'll finally get that dyno so we'll know what a NA 7AFE can push out smile.gif
post May 21, 2005 - 7:49 PM
rocky2006
Joined Aug 18, '04
try to get the numbers up here asap biggrin.gif.
post May 21, 2005 - 9:28 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(rocky2006 @ May 20, 2005 - 12:56 AM)
[right][snapback]289216[/snapback][/right]
What GT3 needs in an engine swap option. smile.gif A 4AGE swap will be cheap and easy enough, and give you lots of power for the money.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
Lo-Fi Version Time is now: May 18th, 2026 - 7:46 AM
