Jul 29, 2005 - 2:40 AM
Ok so i'm at work thinking again.. after reading some post.. and having some mental flash backs.... here is a questions or statment .. you guys pick what it is..
why doesn't changing the exhuast on the celi do anything.... well could it be cause the stock exhuast (on GT's) is pretty much sright compared to other cars..and going from 2.25 to 3 is like making a 4 lane highway in a town that only has 3 cars .... then there the whole thing with toyota's engine saving ECM ... -------------------- |
Jul 29, 2005 - 4:07 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
it has some effect, but modern cars are designed with back pressure in mind. From what I understand, backpressure is actually needed in our application (stock) because that is how the engine is tuned to run. So while you actually may gain a couple of hp, you may actually lose some tq!
Please correct me if I'm wrong? Its pretty late and i cant sleep worth ****... -------------------- AIM : FAQdaWorld
Jul 29, 2005 - 4:53 PM
Enthusiast ![]() ![]() Joined Jan 27, '05 From Rockville, MD Currently Offline Reputation: 1 (100%) |
I am sure you can gain hp and torque if you had headers and an exhaust. Because the headers will allow more exhaust to move through freely therefore having a slightly bigger exhaust such as the Greddy one should gain you something.
Jul 29, 2005 - 6:00 PM
Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
gives u sound and faster rev...decreases backpressure and requires high rpms for torque
Aug 1, 2005 - 10:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Engines need backpressure to run = myth.
Cars do not need backpressure -- it's a myth. Backpressure is an inevitable consequence of not having a variable exhaust size. The harder the engine is working, the more exhaust it needs to get rid of, and the ideal situation would be for the exhaust pipes to grow as the engine pumps out more fumes. Since we don't have that technology, what we do is pick a compromise size. It's not as efficient at low revs as a small pipe, because the exhaust gases have room to expand, cool and slowdown, reducing the scavenging effect and forcing the engine to expend energy on moving what is now heavier gas. At high revs it's not as efficient as a larger pipe, because the gas bottlenecks. Either way, you get backpressure. Really big pipes are good only if you're producing enough exhaust to be efficiently using them. This is why FI need larger pipes. The turbo/supercharger or NO2 system is essentially virtual displacement, burning more gas and creating more exhaust. The same rules of physics and fluid dynamics apply to all exhaust, whether it's generated by pulling air into an engine or forcing it in. Still an internal combustion engine. The backpressure myth is best punctured by the fact that really large pipes on a small engine, because they let the gas expand and cool, end up creating greater backpressure and reducing scavenging than a small pipe. The big pipes have less initial backpressure, but create their own. Stock pipes are generally smaller than those who like performance want because they are designed to create the most efficient flow at low RPMs, to improve acceleration and everyday drivability. Performance-oriented owners typically spend more time at high revs, when a slightly larger set of pipes would be most efficient. In short backpressure is always bad. The trick is to get high exhaust velocity and low backpressure when you need it. Bigger pipes is the easiest, but least effective way of improving flow. |
Aug 2, 2005 - 11:38 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Galcobar, that's an EXCELLENT post. He hit the nail on the head everyone.
| Lo-Fi Version | Time is now: August 26th, 2026 - 1:36 AM |
