> A/C problem
post Aug 4, 2005 - 6:42 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
ok, its getting REAL hot around here and my g/f won't stop bitching about me not using my a/c.
i tried it a couple weeks ago and it was blowing cold air. figured it needed charged. took it to a friend that charges a/c systems and he said it was full. said my a/c clutch wasn't engaging.
any way to fix it, or am i gonna have to just replace it.
im getting my windows tinted soon and sitting in a black interior, windows up in 100 degree weather WILL NOT FEEL GOOD!!
lol
Jared Harwell
post Aug 4, 2005 - 8:02 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Depends on what's wrong. You can try applying 12 volts directly to the black and white wire going to the compressor. If it engages then I'd say check your A/C relay and pressure switch. This is all assuming you've checked your fuses first.
EDIT: This may help - http://wannabegt4.myftp.org/aircond.pdf
This post has been edited by WannabeGT4: Aug 4, 2005 - 8:07 PM
post Aug 8, 2005 - 1:22 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Any luck?
Lo-Fi Version Time is now: August 31st, 2026 - 7:29 AM
