Aug 8, 2005 - 10:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
How is something like a desired air/fuel ratio calculated?
the way a stock ecu determined lean/rich is just a factor of More/Less, but a wideband gives you the actual numbers. I'm curious how these numbers can be determined. ex, a 3s-gte runs _ for a stock air/fuel, but a 5s-fte runs ~12(looking @ manny's tuning) does the air/fuel ratio take into account the increased air-pressure? basically just looking for any info you have on these ratios...the book i'm reading kinda skimmed the top of it all edit: also, just making sure my logic is correct. a stock O2 sensor goes after the combustion chamber, but if turbo also after the air is brought back to regular pressure.... a stock o2 sensor just reads rich/lean and the ecu adjusts accordingly a wideband O2 sensor goes in the same place, but has a different fitting. It on the other hand reads a value. instead of rich/lean it gives the #'s we are talking about. This post has been edited by Consynx: Aug 8, 2005 - 11:18 AM -------------------- ![]() |
Aug 8, 2005 - 11:12 AM
steve, in most cases, a stock 3s runs REAL rich. around 10:1 or so especially in the higher rpms..
its made to be real rich like that cause rich = safe, even if you loose a couple HP. ideally you'd wanna see it around 11.5-12:1 on a turbo car. some say 12.5:1 is still safe, but i like to personally stay a little more on the safe side. basicly leaner = more power/ closer to detonation richer = safer...up to a point..then its just a waste. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: August 31st, 2026 - 11:09 AM |
