May 1, 2003 - 7:53 AM
Enthusiast ![]() Joined Sep 18, '02 From Masachusettes Currently Offline Reputation: 0 (0%) |
someone should post a how-to artical on instaling a turbo and were they got the parts from and how much labor and cost is. just an idea
May 1, 2003 - 8:21 AM
yea i agree
May 1, 2003 - 9:29 AM
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
here's the minimum list:
turbo manifold oil lines bigger injectors FMU or AFC fuel pump blow off valve IC (optional: needed for more than 5 psi) piping custom downpipe intake filter turbo flange a/f gauge (not needed if you got an AFC) boost gauge egt gauge gauge pod check valve optional: external wastegate boost controller turbo timer more gauges ignition timing controller any other goodies you want you'll also need stuff like oil, gaskets or gasket maker, hoses, etc. i spent about 3500 so far, i definitely went the most $$ route you could go, i bought everything new, and added a lot of optional stuff. prices depend on what you get, labor depends on where you go. if you have any questions about the install, post em. you really should read up and do some research yourself. turboing is tricky, and it's better if you understand exactly what's going on with your car. i've spent close to 3500 on my 7afte, but you can get it done probably for 2000 if you buy used stuff and really shop. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
May 1, 2003 - 9:48 AM
this is why i changed the entire engine - its cheaper and will last longer.
May 1, 2003 - 11:43 AM
thanks
May 1, 2003 - 12:03 PM
Enthusiast ![]() ![]() Joined Nov 6, '02 From Chicago, IL Currently Offline Reputation: 0 (0%) |
yea but if I put turbo on my beefy "Automatic"....hehee.... one word!!!!! SLEEPER (i wanna see 7afe get into 13s though) |
May 2, 2003 - 1:33 AM
ha, good luck with that. -------------------- 1994 Lexus ES300
May 2, 2003 - 8:49 AM
...la...la...la...
well, I have seen Corollas equiped with 7AFE get into 13s (the only problem - they they were "not Auto") but it's always possible to beef up auto trans (**** my handles 14.7 QM) |
May 2, 2003 - 11:56 AM
Enthusiast ![]() ![]() Joined Apr 28, '03 Currently Offline Reputation: 0 (0%) |
Race Prepped 3sge will kick some serious ass, gee...someone should do that...
May 3, 2003 - 11:25 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 20, '03 From Chicago Currently Offline Reputation: 0 (0%) |
How do you do that Ziggy? |
May 3, 2003 - 3:23 PM
custom bro, custom...... I see that you live in Chicago... If you need any hookups let me know.... |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 3:28 PM |
