> How to replace a steering wheel?, Failed DMV inspection.
post Sep 8, 2005 - 8:17 PM
percyv143
Joined Sep 8, '05
Hi. I need to change back to my old stock steering wheel since it failed the DMV inspection. I have a Momo steering wheel. I know I can remove the rubber on the front and expose small allen type screws.. How do I replace it. Is it by removing those allen screws will remove the cover(?) and expose the nut to remove the whole steering wheel? Thanks.
post Sep 8, 2005 - 8:28 PM
Hanyo
Joined Aug 16, '03
From Bay area
after you take off all the screws, you will be left with one big nut at the middle of the steering colum. You need a press tool to help pull the wheel off the car.
after that just re-install your other steering wheel.
post Sep 8, 2005 - 8:51 PM
percyv143
Joined Sep 8, '05
If I don't have a press tool, can I still take it out manually? Is a press tool like a "puller"? Thank you.
post Sep 8, 2005 - 9:04 PM
Hanyo
Joined Aug 16, '03
From Bay area
press and puller tool is the same thing. You can try to remove it with out the tool. But i would be alot harder.
post Sep 8, 2005 - 9:12 PM
I do believe that aftermarket hubs usually aren't pressed on very tight. Once you remove the nut, the hub may remove without a puller.
Lo-Fi Version Time is now: August 27th, 2026 - 6:14 PM
