> What is a crankcase?
post Sep 9, 2005 - 12:55 PM
eyohannie
Joined May 20, '05
From San Diego, California
I bought this oil treatment product that says it will stop the smoke my car makes when it starts up by sealing up something, but it says to put the product in the crankcase. Is the crankcase the same thing as where the engine oil goes?
post Sep 9, 2005 - 1:01 PM
nik
Joined Sep 30, '02
QUOTE(eyohannie @ Sep 9, 2005 - 10:55 AM)
[right][snapback]332544[/snapback][/right]
pretty much
post Sep 9, 2005 - 2:50 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
sounds like that stuff that sticks to all the seals to kind of recondition them as much as possible aka valve stem seals... one of the most common places for oil to leak into the chamber. did i get the right impression here?
post Sep 10, 2005 - 12:04 AM
eyohannie
Joined May 20, '05
QUOTE(celicast3sgte @ Sep 9, 2005 - 2:50 PM)
[right][snapback]332589[/snapback][/right]
yup. i'm going to check it in the morning to see if it really works.
post Sep 10, 2005 - 10:45 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
oh no....
ok, the oil on startup is the seals around your valve stems. It happens with wear. If you put that crud in your oil. It will make it thicker and gum up some of the narrow passages reducing the smoke on startup. BAD IDEA!!!
If something you add to your oil increases the viscosity to prevent one problem it is sure to cause many other problems ie: blocking oil pasages to the heads...
Keep driving the car with regular oil changes, if the engine starts to die, replace it or rebuild it. The one sure thing the 'additive' will do is kill your engine sooner.
my $0.02
post Sep 10, 2005 - 10:56 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
if the smoke is new it's not a HORRIBLE thing. You can get a valve job done. as long as the prob is minor i doubt you'd even notice a real chance in oil level during oil changes.
Lo-Fi Version Time is now: September 3rd, 2026 - 5:11 PM
