> Injen Intake HELP!
post May 4, 2003 - 9:26 AM
Stipt
Joined Apr 29, '03
From Davenport, IA
When I took out my air filter box, there is like a hole on the right wall under the hood that my filter is pointing too. Is that were the air comes in? And should my filter be touching it or is it fine a couple inches away? Also when I start my car I get this weird noise from under my hood. Kind of high pitched. I was wondering if this was the intake or not. Thanks!
post May 4, 2003 - 10:27 AM
yup it stays a couple inches away...and yes that is the intake your hearing...go for a blast and hear it roar above 3200rpm...lol biggrin.gif
post May 4, 2003 - 11:18 AM
Stipt
Joined Apr 29, '03
From Davenport, IA
Oh man I love it run my car now. I leave for work like 30 minutes earlier now so I can drive around 45minutes before work LOL that holds me over for 8 hrs then I drive for like 45minutes home hehehe. Right now I think I'm gonna save up for a 3sgte setup. I found one on the net, 87-90 toyota-celica ta63 3t-gte+5spmt (complete motor, + ecu + wire harness) Does that look good? Calling to check on price tomorrow
post May 4, 2003 - 12:08 PM
you'll be better off with a 2nd gen (90-93)
post May 4, 2003 - 11:58 PM
Stipt
Joined Apr 29, '03
From Davenport, IA
what about this engine: 90-95 toyota-celica st185 3s-gte+5spawdmt (front clip) 225hp
Its for sale for 1500+shipping. That betta?
post May 5, 2003 - 12:10 AM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
well shoot since ur plannin on swappin i call dibs on ur exhaust and intake biggrin.gif
post May 5, 2003 - 3:12 AM
CelicaSX
Joined May 1, '03
From Victoria, Australia
Hi all,
Just a note the hole in the right wall is for the air intake, but it is not forced. Its sucked up inside the front guard. Once you remove the box it breaks the vaccume seal and it becomes useless for cool air.
A better idea for forced cold air intake is to run a 3inch Flexible water pipe. Those sold at landscaping shops and run it from next to the Battery (attach with zip locks) pointing at your filter pod and run down past behind the radiator & the Clutch mech.
From here cut a whole or widen the air vent on the bottom plastic splash guard and poke the pipe out from here facing forward so air is pushed in.
A good tip is to place an old stocking over the end on the pipe to stop leaves & old cig butts from getting under the hood from the pipe.
To aviod heat soak wrap the pipe in Industrail foil a coupel of time and duct tape or zip tie into place.
Cheers
post May 5, 2003 - 10:39 AM
Stipt
Joined Apr 29, '03
From Davenport, IA
****........why shouldn't I keep my exhaust???
post May 5, 2003 - 12:44 PM
claudio
Joined Nov 15, '02
From california
so if the car was grabbing cold air from the stock filter through that stock tube and you replace it with a injen intake-- now the car is getting more air which is good, but it is now hot air versus previous cooler air from that stock tube which is bad. So it seems there isn't any performance gains?
post May 5, 2003 - 12:54 PM
95STCelica
Joined Oct 12, '02
From New Jersey
What is this, everybody get a 3sgte week..man im so depressed it ain't funny
post May 5, 2003 - 4:15 PM
bonzaisushi
Joined Oct 3, '02
why would u want that exhast... UR TURbo DUDE!!!! u can go bigger tongue.gif
post May 5, 2003 - 4:53 PM
Stipt
Joined Apr 29, '03
From Davenport, IA
hehehe good point. Well anyways....I might actually be able to get one done this week. I got the name of a great drag race mechanic and he does side jobs from the business so it will be cheaper. I heard he can do anything mechanical so! I'mma call him tomorrow and see what he says. Bonzaisushi, ya want my exhaust and intake? Drop me an email or MSG me on yahoo. Pyro_catalyst is my Yahoo name or my email is computer_er@excite.com Laters
Lo-Fi Version Time is now: August 31st, 2026 - 9:36 AM
