> Gauge install, Engine temp gauge problem
post Sep 29, 2005 - 12:20 AM
blu94gt
Joined Mar 23, '05
From Kansas City
Ok so I was curious about installing my gauges. I've got a 3 gauge setup with a voltmeter, oil pressure and coolant temp. The oil pressure and coolant are mechanical. Now the oil pressure I understand with the T head etc etc how to install, but the coolant one I was curious about. Where is the sensor for the engine temp located (my manual says near the distributor, but I just want to make sure bc it is outdated), and do I have to remove the original one or is there a place I can drill for a new one? The reason is I don't want to lose function of my stock temp gauge in my cluster so i can install this one. The manual for the gauges says just to replace the car's stock temp sensor with the one for this gauge. Where is a good place to drill for a new sensor to be placed?
Oh and yes I did search, searched my butt off lol there wasn't much useful information
1999 Celica GT
post Oct 6, 2005 - 11:12 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
:rolleyes: The temp gauge can be hooked up with the sensor that sends the temp feedback to the ECU. It is a two wire connection. Just take off the sensor that sits above the termostat or near there (the temp sensor) and splice the gague wire into one of the wires. (Note: one wire for the sensor is ground the other is the one you want to tap to, u might need a voltimeter for this to find the ground wire and eliminate it) Once you tap into it your gauge should function properly. provided u hook up the 3 remainng wires for 12+,GND,and 12V+ for night driving.
post Oct 7, 2005 - 12:18 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(soulshadow @ Oct 6, 2005 - 11:12 AM)
rolleyes.gif The temp gauge can be hooked up with the sensor that sends the temp feedback to the ECU. It is a two wire connection. Just take off the sensor that sits above the termostat or near there (the temp sensor) and splice the gague wire into one of the wires. (Note: one wire for the sensor is ground the other is the one you want to tap to, u might need a voltimeter for this to find the ground wire and eliminate it) Once you tap into it your gauge should function properly. provided u hook up the 3 remainng wires for 12+,GND,and 12V+ for night driving.
[right][snapback]341724[/snapback][/right]
thanks, i actually figured this out soon after i posted this, i found a wiring diagram online from a guy who turbocharged a camry and that helped me with everything. thanks tho, i'm just not experienced in some of this kinda stuff
1999 Celica GT
Lo-Fi Version Time is now: August 31st, 2026 - 10:22 PM
