> PIC request..., 3sgte dipstick...
post Oct 13, 2005 - 12:32 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
hey guys, im making progress with my swap. i just need to get oil in it before i try starting her up. i just dont have the dipstick in. i found the hole where it goes, but i need a pic of where it sits when its in, and where the bracket bolts onto the engine.
thanks!
post Oct 13, 2005 - 10:42 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
post Oct 13, 2005 - 11:10 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
cool, that helps a lot. THANKS!
post Oct 13, 2005 - 11:18 PM
mark_426 ... you mind taking a pic that shows the clearence between the koyo radiator and the downpipe? sort of like a top side view pointing down.
post Oct 14, 2005 - 12:09 AM
mark_426
Joined Jan 30, '05
Heres one I took a few min ago. I can take a few more, but also look here : http://www.6gc.net/forums/index.php?showto...=0&#entry344480
post Oct 14, 2005 - 12:18 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I will return one day.
post Oct 14, 2005 - 12:20 AM
mark_426
Joined Jan 30, '05
post Oct 14, 2005 - 12:21 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
i did already. I see a front mount, no piping to connect it to the turbo
post Oct 14, 2005 - 12:28 AM
mark_426
Joined Jan 30, '05
QUOTE(mark_426 @ Oct 14, 2005 - 12:56 AM)
I've had it in the garage since tuesday, trying to fix the oil leak and turbo problems.. no time to polish it when going to college, working 15-30hrs a week, and fixing the mechanics.
Before anyone says anything - I need to get my **** together and cut, bend, and weld up my intercooler piping and exhuast. (The intercooler is not plumbed, exhaust midpipe is stock). See above.
[right][snapback]344480[/snapback][/right]
post Oct 14, 2005 - 12:39 AM
thanks for the pic... that koyo looks like it wouldnt fit with my ic piping .a good thing to know ahead of time.
dont boost at all without the ic. id be so scared to even drive it like that.
post Oct 14, 2005 - 6:58 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
low boost.... no IC
post Oct 14, 2005 - 1:02 PM
found a great pic for you, man!
EDIT: crap, just realized this is probably form an mr2, but it might still help u
This post has been edited by lagos: Oct 14, 2005 - 1:03 PM
post Oct 14, 2005 - 1:20 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
awesome!
yeah thats for an mr2...but i have an mr2 motor so that's relevant. so that problem is, where the tube bolts on...i dont have a bolt there...that goes to the radiator, and i got a new radiator and that piece doesnt look like that anymore, nor does it have that bolt.
post Oct 14, 2005 - 8:00 PM
yeah like i tried to tell you before.... somone i know put an mr2 motor into their celica and had to convert over to the alltrac dipsitck and holder. you might have to track on of those down or buy it new from toyota
post Oct 19, 2005 - 11:19 AM
Punch
Joined Jan 29, '04
junk yard............
post Oct 19, 2005 - 2:47 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
oh crap that koyo radiator is tight in there...id never be able to get that to work with my clocked turbo! frown.gif
bboy
post Oct 19, 2005 - 11:32 PM
mark_426
Joined Jan 30, '05
QUOTE(BBoYRuGGeD @ Oct 19, 2005 - 3:47 PM)
bboy
[right][snapback]346481[/snapback][/right]
I'll let you know... turbo is clocked, wastegate actuator is mounted.. coolant, oil, and vac are hooked up... just waiting on getting some piping in and bent... and then I'll have pics. Yaay.
Lo-Fi Version Time is now: August 25th, 2026 - 5:58 PM
