Oct 23, 2005 - 9:52 AM
Enthusiast ![]() ![]() ![]() Joined Nov 26, '03 From Texas Currently Offline Reputation: 1 (100%) |
every time i drive on this one road which is very bumpy, i hear this knocking around noise in the back coming from the trunk. It sounds like a block of wood knocking around back there, but i cant find what it would be, anyone else have this problem or know what it is?
-------------------- It's not just about getting from point A to point B anymore....
Oct 23, 2005 - 10:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I had this problem. For me it was the tire tools in the hatch moving around, I wrapped them all in towels and secured them properly. Problem solved.
Oct 23, 2005 - 11:41 AM
![]() Enthusiast ![]() ![]() Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
might be ur muffler or exhaust tubing!!!
-------------------- <<AKA THA RUSSIAN>>
Oct 23, 2005 - 11:48 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) |
I'd have to agree with Cutrara. Make sure your spare and all your tools back there are secured properly.
-------------------- ![]() A Jaws4God Creation... |
Oct 23, 2005 - 12:13 PM
Could be struts.
Oct 23, 2005 - 12:21 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) |
i noticed the same noice after i replaced my struts, haven't had a chance to jack the car up to find out the exact location of the noise
Oct 23, 2005 - 12:31 PM
its not the tools, ive already checked that. This was also before i got my new struts in also. Its not metal against metal sound, idk, i might just have to deal w/ it.
Oct 23, 2005 - 2:05 PM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
try replacing rear sway bar bushings... i think they're only like 6 bucks from the dealer and really easy to change out.
Oct 23, 2005 - 3:12 PM
just realized that my strut bearing and strut mount might need to be replaced, that could be causing the bumping noise for me
Oct 24, 2005 - 12:26 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
check that your scissor jack isnt moving around as well. if i had to put money on it tho, i would say its your rear sway bar bushings that attach to the chassis, mine are worn and it is causing the same noise problem.
Oct 24, 2005 - 7:35 AM
Enthusiast ![]() ![]() Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
Well for me it was the dead body sorta the price you pay for being a mafia lacky but they say I'll move up soon.
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Oct 24, 2005 - 8:17 AM
I live with it everyday. I think its the movement of the struts. I don't have any tools nor a spare and it still does that.
Oct 24, 2005 - 3:54 PM
QUOTE(FSX_Celica94GT @ Oct 23, 2005 - 1:31 PM) its not the tools, ive already checked that. This was also before i got my new struts in also. Its not metal against metal sound, idk, i might just have to deal w/ it. [right][snapback]348036[/snapback][/right] QUOTE(celicarus @ Oct 23, 2005 - 4:12 PM) just realized that my strut bearing and strut mount might need to be replaced, that could be causing the bumping noise for me [right][snapback]348073[/snapback][/right] if everything is secure in the hatch/trunk area, then most likely it is the rear strut mounts. You can buy new ones from the dealer (don't bother buying crappy aftermarket ones) and replace them. The job isn't too difficult start to finish, you just need the right tools and no fear. Manny and I replaced them on his car. I have the "bumps" back there too and I will probably be doing mine next summer. QUOTE(Snarfer @ Oct 23, 2005 - 3:05 PM) try replacing rear sway bar bushings... i think they're only like 6 bucks from the dealer and really easy to change out. [right][snapback]348060[/snapback][/right] I agree. Those are next on my to do list. -------------------- |
Oct 24, 2005 - 4:38 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
i'm 99% positive it's ur strut mount, i recently got fet up of the exact same problem. what a pain that was (the knocking sound). Replacing it was extremely easy and man am i ever glad i fixed it, it was driving me nuts !
One way to check is pop off the strut tower caps, look inside where the bolt is, push/pull the car up and down and if you see it move then thats what it is. -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Oct 25, 2005 - 12:46 AM
Enthusiast ![]() ![]() Joined Oct 10, '05 From San Diego Currently Offline Reputation: 2 (100%) |
check the cover the sits right behind the rear seats that moves up and down when you open and close the hatch
it used to do that to me... it sounds exactly like logs rolling around |
Oct 25, 2005 - 1:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I have that problem all the time, I just go back there and slap them around a little bit and tell them to knock it off, or else I'll keep the ransom money and kill them anyways. Usually they quiet right down.
Hope that helps. -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 25, 2005 - 4:10 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
I had that problem with my civic, every big bump I hit I would hear a klunk, it ended up being my strut, I had coilovers on, and stock struts, witch on one side bent it enough to let the top of the strut (where the bult is that holds the top mounting peace to the shock) so that it could slide almost freely from it up and down. (makes for a bad ride too)
Oct 25, 2005 - 8:59 AM
![]() Enthusiast ![]() Joined Apr 13, '04 From St. Louis (Webster Groves) Currently Offline Reputation: 0 (0%) |
I have the same problem in my celi... I always thought that my trunk didnt close really tight and that it was bouncing over big bumps. How do I get to the strut mounts on a coupe? That could be it.
Oct 25, 2005 - 8:12 PM
anyone kno where to get the OEM rears? i can only find the fronts, says they're KYB's.
Struts The OEMs are the cheapest, but only the fronts are on there, along w/ all the other sites. -------------------- It's not just about getting from point A to point B anymore....
Oct 26, 2005 - 12:39 AM
for oem struts and shocks go to Auto Zone or a Schucks, thats one good thing about thoes stores is getting good priced oem replacements pretty easaly.
| Lo-Fi Version | Time is now: August 29th, 2026 - 10:35 AM |
