> Highest Octane, Pump Gas
post Nov 6, 2005 - 12:20 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I need to know what the highest possible UNLEADED PUMP GAS. I heard a gas station here sells 110 unleaded octane gas. Is there any higher ones out there? Remember, it has to be unleaded and from a gas station.
post Nov 6, 2005 - 2:42 PM
why do u want anything that high, its not going to make the car run any better or faster. i run 94 in mine, thats the highest i can find. anything higher is probably race gas.
post Nov 6, 2005 - 4:04 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I don't need to know it so that I can stick it in the 7A. If I'm not mistaken, my car runs perfectly fine with Regular 87 Octane(cheap stuff). I just want to know for my own knowledge. I know here they sell 110 pump gas and it's not race fuel. It's a normal gas station. So I wanted to know if it's higher in other states. unleaded pump gas. im not interested in the leaded and race fuel/jet fuel, etc. lol.
post Nov 6, 2005 - 4:15 PM
I think most states are maxed out at 94, everyone I been in NY its 93. 110s rare.
post Nov 6, 2005 - 5:51 PM
Mr_E
Joined Nov 16, '04
From UK
110 MON?
Jeez that's high. Do they have aircraft landing there regularly to fill up?
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Nov 6, 2005 - 5:56 PM
no we're RON.
The UK uses MON, Japan uses PON, we use RON, which is the average of the 2.
This post has been edited by Supersprynt: Nov 6, 2005 - 5:56 PM
post Nov 7, 2005 - 12:51 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(JoKeRkId613 @ Nov 6, 2005 - 4:04 PM)
[right][snapback]353804[/snapback][/right]
Are you talking about the Sunoco gas station on Okeechobee Road (US27)? If so then thats 110 Octane LEADED race fuel.
post Nov 7, 2005 - 9:47 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If you can get a hook up, go fill up at the airport on some Jet fuel.
A few friends of mine does this, but you can only get away with only 1-2 gallons, b4 somebody catches on to the missing gas.
post Nov 7, 2005 - 10:16 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Supersprynt @ Nov 6, 2005 - 5:56 PM)
no we're RON.
[right][snapback]353854[/snapback][/right]
UK is RON. I thought the US used MON which gives a lower (but more accurate) octane rating.
JDM ST205
post Nov 7, 2005 - 11:06 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Supersprynt @ Nov 6, 2005 - 4:56 PM)
no we're RON.
I think you've got it a little mixed up.
Our pumps say R+M/2 so we've actually got the average of RON and MON (aka PON "Pump Octane Number"). I thought everyone else uses RON (Research Octane Number). I've never heard of anyone using MON (Motor Octane Number).
post Nov 7, 2005 - 6:16 PM
Ok I had it a lil mixed up. We're PON. Hey, theres only a lil line that changes a P from an R.
post Nov 8, 2005 - 10:43 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(WannabeGT4 @ Nov 7, 2005 - 11:06 AM)
no we're RON.
Of couse, yes. That's what you use over here.
Thanks for the clarification.
What ever it is, it's cheap...
JDM ST205
post Nov 8, 2005 - 11:08 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
By cheap do you mean inexpensive or do you mean of lower quality? 'cause the quality is just as good as everyone else just rated different. The price is cheap compared to you but not compared to what the middle easterners pay.
US (R+M)/2---vs---UK (RON)
87---------------------------90
89---------------------------92
91---------------------------95
92---------------------------96
94---------------------------98
96---------------------------100
post Nov 8, 2005 - 11:12 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Hey J, how'd you find the research and motor numbers for the US?
post Nov 8, 2005 - 11:26 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
They're aproximates from the table on this site:
http://www.btinternet.com/~madmole/Reference/RONMONPON.html
First result from RON MON google search.
post Nov 8, 2005 - 1:06 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(WannabeGT4 @ Nov 8, 2005 - 11:08 AM)
I mean inexpensive. I have wet dreams about sub £2 gallons.
JDM ST205
post Dec 2, 2005 - 3:01 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I have offical News that NAPA does indeeed sell 99 Octane, but only some big stores have it.
post Dec 2, 2005 - 4:16 PM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(lagos @ Nov 6, 2005 - 7:42 PM) [snapback]353777[/snapback]
Not true...higher octane gas will make your car run better, it increases fuel economy and increases HP, it help stops pre detonation (knock) in hot engines, burns cleaner and produces less polution, I always run the highest octane I can find....usually 98Ron If I could find 110 Ron in the UK I`d use it. 100Ron is the highest we get here.
post Dec 2, 2005 - 9:02 PM
i used 104 unleaded US rated gas in my jetta running high boost at the drag strip
post Dec 2, 2005 - 9:18 PM
QUOTE(Insanity-74 @ Dec 2, 2005 - 4:16 PM) [snapback]362599[/snapback]
well i was talking about the orignal poster not needing anything higher then 87 octain in his st. turbo charged engines are different and benefit from higher octain, so i totally agree with you there.
Lo-Fi Version Time is now: August 11th, 2026 - 12:34 PM
