Nov 23, 2005 - 5:13 PM
Enthusiast ![]() Joined Nov 21, '05 From Quebec Currently Offline Reputation: 0 (0%) |
I want overhaul my st205 engine before put in my st204
I need part number of st205 engine: timing belt water pump thermostat spark plug wire fuel filter oil filter rear main seal and any other stuff I can need to use. tanks -------------------- Celica GTS turbo 1994
3sgte genIII Ct20b |
Nov 23, 2005 - 5:15 PM
That doesnt look like an ST205 engine, thats an air to air on top there and ST205s came with water to air. That looks like a 3s outta an ST215.
This post has been edited by Supersprynt: Nov 23, 2005 - 5:15 PM -------------------- |
Nov 23, 2005 - 5:21 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Yeah that's definately a 4th gen 3S from the Caldina. Good luck finding anything for that.
-------------------- ![]() Project ST204.5 99.88946% complete... |
Nov 23, 2005 - 5:23 PM
I need to take new pics
this is my first engine (st215) I cannot able to find ecu for this one so I buying new one st205 engine If some one know where find st215 ecu it's can be fun -------------------- Celica GTS turbo 1994
Nov 23, 2005 - 5:29 PM
Ask Fensport.com, they maybe able to help you.
Nov 24, 2005 - 11:00 AM
i think a member here named 'hisashigt94' or something can get you the part number for it..
Nov 24, 2005 - 11:04 AM
Nov 24, 2005 - 1:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Most, if not all of those parts should be the same as any Gen III 3SGTE motor which means MR2 as well.
Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 24, 2005 - 5:13 PM
The other thread is for jdm Exterior Styling
I going to see in mr2oc forum for import there some part number -------------------- Celica GTS turbo 1994
Nov 24, 2005 - 10:16 PM
Enthusiast ![]() Joined Jun 14, '05 From Honolulu Currently Offline Reputation: 0 (0%) |
i would think the parts that you are looking for the 3rd gen 3sgte would work with the usdm parts. Just try it out and see. There wasn't that much change to the 3sgte motor over the years. For an oil filter, try a fram oil filter for an all trac or an mr2. It should work. Just buy it and if it doesn't fit then return it.
Nov 27, 2005 - 8:16 PM
Enthusiast ![]() ![]() Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) |
Caldina ST215 Parts List
This engine uses a direct fire ignition system. These part numbers are different than those for a ST205 Timing Belt - 13568-79105 (nov-93 to aug-99) Water Pump Assembly - 16100-79225 (june-97 to xxxx) Thermostat - 90916-03100 (nov-93 to aug-99) Spark plug(PK20R8) - 90919-01180 (nov-93 to aug-99) Spark Plug Cord Set - (none used- direct fire) Spark Plug Coil Pack Assembly - 90919-02227 (aug-97 to xxxx) 4 required Fuel Filter - 23300-19465 (aug-97 to xxxx) Oil Filter - 90915-10002 (aug-97 to nov-99) Oil Filter - 90915-10004 (nov-99 to xxxx) Rear Main Seal - 90311-89001 (aug-97 to xxxx) Engine ECU 89661-21320 (aug-97 to xxxx) (for manual transmission) I have the same ignition system on my motor. I found the coil packs to be in very good condition. Yours are probably fine also. Check your motor to see if you have plug wires and a distributor. If you do not, then a ST205 ECU will NOT work. The plugs are fired directly from the ECU and the ST205 ECU does not have this ability. This post has been edited by Outsider: Nov 27, 2005 - 8:54 PM -------------------- ![]() 1994 GT-S (BEAMS) swap complete |
Nov 29, 2005 - 12:02 AM
tanks for ST215 info and will be very usefull for futur Celica turbo swap
Now I have change the way for my swap and go for more easy ST205 swap If some one can leave the same information about ST205 it's very usefull for me tanks This post has been edited by 3rdgen3SGTE: Dec 3, 2005 - 11:57 PM -------------------- Celica GTS turbo 1994
Jan 3, 2009 - 1:07 AM
Im not dead...
4 year after my swap is not done ...lol have not time to work on that I wait for jdm st205 1994 complet car can import in canada after 15 year part number for entire car and engine is usefull or microfiche -------------------- Celica GTS turbo 1994
| Lo-Fi Version | Time is now: August 29th, 2026 - 5:20 PM |
