> Car alarm install
post Nov 23, 2005 - 9:35 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I spent all day installing my car alarm and it's still not completely done. Most of the morning involved taking the front fender off so I could bury the siren and run the wires into the interior. All I have left is to wire in the trigger to set it off when the doors or liftback are opened. From everything I can see in the wiring diagrams and in the paperwork that came with my alarm it should be a red/white wire at the fuse panel. I found a connector under the fuse panel with a red/white wire on it, unplugged it, the dome light went off. Must be the one right? When I cut the red/white wire going to that connector and plugged it back in the dome light still came on.
Anybody know off hand if I got the right wire?
The alarm came from Crutchfield, it's the 533i. It has a lot of nice features: keyless entry, locks the doors when you turn the key, unlocks when you stop. It is able to pop the trunk but I need some sort of solenoid to make it work. Has anyone done this and can you tell me how to do it?
Thanks
post Nov 23, 2005 - 10:55 PM
check here
http://www.6gc.net/forums/index.php?showtopic=16174
and here
http://www.6gc.net/forums/index.php?act=ST&f=7&t=11174&st=0
post Nov 24, 2005 - 12:43 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(Batman722 @ Nov 23, 2005 - 7:55 PM) [snapback]359120[/snapback]
Thanks, now I remember seeing those threads before. I just need to find where I saw how to wire the trunk popper
post Nov 24, 2005 - 1:04 AM
they are all at the top of the interior forum in the sticky
http://www.6gc.net/forums/index.php?showtopic=27828
post Nov 24, 2005 - 5:07 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE(Batman722 @ Nov 23, 2005 - 10:04 PM) [snapback]359169[/snapback]
I had the wrong red/white wire for the trigger (there's like five under there). Got the right one now, everything is working great.
Where did you get your solenoid? I'm assuming a door lock actuator will work for this. I'll just set it up to pull in one direction only though.
Lo-Fi Version Time is now: August 11th, 2026 - 11:31 AM
