> wanting to convert ST to GT brakes FRONT, questions and info
post Nov 28, 2005 - 12:23 AM
I have done some searching and from what I have found, for someone to convert their ST brakes to GT brakes in the FRONT, they would need
GT front
calipers
rotors
pads
backing plates
and lines
is there anything else ? is the hub needed to be swapped as well ? or are the above parts direct bolt on to ST hubs ?
thanks guys
post Nov 28, 2005 - 12:45 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
what you have looks like all that is needed. the hubs are the same
post Nov 28, 2005 - 10:52 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
I've also done the ST->GT front swap. You will be fine with the parts you have above. I actually used the ST lines with no problems, and scrapped the dust covers/backing plates.
post Nov 28, 2005 - 12:23 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE(Batman722 @ Nov 28, 2005 - 12:23 AM) [snapback]360354[/snapback]
GT front
calipers
rotors
pads
backing plates
and lines
thanks guys
By bracking plates do you mean the brake Brackets??
post Nov 28, 2005 - 6:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
All you need are calipers with brackets (and pads of course) and rotors (assuming it's 6gc GT to 6gc ST). Brake lines are the same... backing plates are the same too.
Lo-Fi Version Time is now: September 14th, 2026 - 12:17 PM
