Dec 6, 2005 - 7:41 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Decided that while the motor and box were out that it would be an ideal opportunity to upgrade the front sway bar. Already done the rear with one from Whiteline, but was unable to locate an 'off the shelf' item for the ST205.
So pulled the original one off and took a trip down to Snells Springs in Auckland who made a copy with a 19mm diameter... ![]() Considerably larger than the standard 15mm it should improve things no end Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Dec 6, 2005 - 8:43 PM
just off hand (im' not sure if i'm remembering quiet right my head feels like a scooby ran into me) but arn't most aftermarket front sway bars like 22mm?
why only a 4mm upgrade? but in other terms your new one is HOT and its sweet that you can just go down to a shop and they will do it for you on spot....places here don't really do that This post has been edited by playr158: Dec 6, 2005 - 8:44 PM |
Dec 7, 2005 - 12:23 AM
I think that a 21/22mm bar would be way too large and would adversely affect the handling - especially on what is basically going to be an everyday car. Go too large on the front sway bar and there is the potential to induce unwanted understeer.
Dec 7, 2005 - 10:25 AM
ah ok thanks for that clear up gary!
Dec 7, 2005 - 3:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 30, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
GT4WRC the Whiteline Sway Bars are coming with bushes?
I hope you will install them soon so you can compare them with the stock one! I choose to go with C-one Sway Bars and they are on the way!! |
Dec 7, 2005 - 5:27 PM
Whiteline rear swaybar came with new bushes and U brackets.
| Lo-Fi Version | Time is now: September 1st, 2026 - 6:06 AM |
