Dec 7, 2005 - 9:29 PM
![]() Enthusiast ![]() Joined Jun 6, '05 From Texas/Hawaii Currently Offline Reputation: 0 (0%) |
i want to get my gauges done and i wnat to buy the pro car parts reverse indiglo gauges and i was wonderin who has them installed and are they really worth it.
-------------------- I gotz 2 things my celi and a dream, the prob is commin up with the thrid one...
Dec 7, 2005 - 9:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Black or white face? Just installed the black ones today.
Dec 8, 2005 - 2:18 PM
i want the face to be black with a red glow did you do any custom design to yours or just the basics? lemme know wats up? is it easy to make a clean install or does it look like you took something apart to change it?
Dec 8, 2005 - 3:04 PM
BLack face with red glow is best done with the stock gauges and just swapping the LED's. I got mine off ebay, they are the procarparts ones im fairly sure. Just overlays...pretty much plug and play.
Dec 8, 2005 - 8:03 PM
Enthusiast ![]() ![]() ![]() Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) |
I just put the reverse indigolo guages in last weekend. They have the silver background. I really like the results, much easier to read. I do have afew small issues though. I neglected to leave the stock pieces in for the warning lights so now they are white and really bright. I'm also getting some light leaking out around the outside of the guages. It's a very small amount but still noticable. I think I just need to seat the bezels better or stick them down somehow.
I used a little glue to hold them onto the original guages and took my time to line everything up just right. I changed the color of my turnsignal indicators while I was in there and painted my needles red with some Tamiya model paint (clear red, X-27). I wanted my odometer to stay white but have red needles. I put two coats of the red on and it turned out a little dark. I think when I take it apart to put the warning covers back in I'll clean it off and airbrush on a lighter coat. |
Dec 9, 2005 - 1:46 PM
thatz cool did you get the metallic silver? i htink im gonna order mine today IMa make sure i take all the time necessary to instally them correctly. Im loking to make em look like they came with the car and not added in a tacky way.
Dec 9, 2005 - 2:45 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
what did you use to change your turn signals? i cant find anything to use in place of those ugly green plastic peices. I wanna make mine red too.
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
Dec 9, 2005 - 2:49 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
QUOTE(JFrost9 @ Dec 9, 2005 - 1:45 PM) [snapback]365321[/snapback] what did you use to change your turn signals? i cant find anything to use in place of those ugly green plastic peices. I wanna make mine red too. Get a cd case and cut out a piece the same size as the ugly green plastic peices. Then put a couple coats of red paint and you're set -------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Dec 9, 2005 - 3:33 PM
Use double sided tape, not glue. Heh. That's if you do this. Because if you take them off then you won't have to remove residue from glue.
BIG TIP!: DO NOT TAKE OFF YOUR NEEDLES Take off the BLACK covers surrounding them. But if you take the needes off entirely, you may screw up the accuracy of your gauges. This isn't HARD to fix but it can be time consuming and ANNOYING. Be careful. -------------------- |
Dec 9, 2005 - 5:08 PM
QUOTE(JFrost9 @ Dec 9, 2005 - 11:45 AM) [snapback]365321[/snapback] what did you use to change your turn signals? i cant find anything to use in place of those ugly green plastic peices. I wanna make mine red too. I found some colored plastic folders at Office Max. I got two shades of blue so I could vary the tint. I have three layers of light blue in right now and it's a little too light to match the indiglo blue. Next time I have the gauges out I'll put in a layer of the darker blue. |
Dec 9, 2005 - 5:19 PM
yea ima get rid of the green turns and make em red also hopefully this project comes out clearly hey peeps if ya got pics post em plz im anxiioius to see wat everyone else did with theres. Soon as mine get here ill do the same
Dec 10, 2005 - 6:14 PM
see i have some folder dividers left over from my clock and what not...and i was wondering if i could just cut out the shape with that, and maybe put in two layers of the plastic (its pretty thick).
Dec 11, 2005 - 10:19 AM
QUOTE(JFrost9 @ Dec 10, 2005 - 3:14 PM) [snapback]365649[/snapback] see i have some folder dividers left over from my clock and what not...and i was wondering if i could just cut out the shape with that, and maybe put in two layers of the plastic (its pretty thick). I would think that would work. The green tabs are like 1/8" thick so you might have to put a thinker piece of clear plastic in there. |
Dec 11, 2005 - 12:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
i just used a rubbing alcohol bottle, cut the peices out and put a red adhesive on them then put them in. and my blinkers are perfectly red my gauges are also custom made, i took the adhesive and made my numbers and lines red, and made the needles white. Havn't got the LED's yet but heres what mine look like
Dec 11, 2005 - 12:37 PM
Dec 11, 2005 - 3:16 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
Akimbo, you have the black face with blue lights??
I wanted to get the reverse gauges from ebay likethese do you have any pics?? |
Dec 11, 2005 - 5:51 PM
an eighth of an inch seems really thick...also, how did you guys pop the old green ones out? i had some trouble popping mine out...
Dec 11, 2005 - 7:57 PM
Just use a dinky screw driver. Doesn't matter how thick or thin the clear peice is. like i said i used a plastic bottle that was clear and put red adhesive on it. and it works perfectly.
| Lo-Fi Version | Time is now: August 11th, 2026 - 8:24 PM |
