> 3sgte question, Circuit opening relay
post Dec 13, 2005 - 6:28 PM
Rjb23
Joined Feb 8, '04
From KY
Everyone who did the 3sgte swap, did you use the circuit opening relay from your gt or st, or did you use the circuit opening relay from you clip?
post Dec 13, 2005 - 10:27 PM
you use the 3sgte cor
post Dec 14, 2005 - 12:09 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Doesn't matter, they both work the same exact way. In fact, you can use either plug and connect either one.
But I tend to use the one that is on the car stock, it's usually less wiring.
Click here to see my swaps
drtweak@phoenixtuning.com
post Dec 14, 2005 - 9:19 AM
Rjb23
Joined Feb 8, '04
From KY
Well I was just wondering because the st185 ECU I got to replace the mr2 ECU that they tricked me with(long story) came with all the ecu plugs, circuit opening relay, COR plug, and about a foot of wiring. I originally used the COR off my st, the part numbers on the 3s COR and the 7a COR are different and I was wondering if this mattered at all.
BTW its amazing how replacing a cali spec 3sgte ecu with a jdm st185 ecu can get rid of all your engine codes and make your car run right, next time I want morons to work on my car I'm just gonna go to the zoo and give the monkeys some hammers and let them go to town.
Lo-Fi Version Time is now: September 1st, 2026 - 10:24 AM
