> Transaxel Oil Seal Replacement
post Dec 21, 2005 - 3:59 PM
jermyd1
Joined Jun 2, '04
From Salem/Corvallis, Oregon
So i had a leak and am trying to replace the seal. the passenger driveaxel is off and im at attempting to remove to old seal but can quite get to it. there is a piece of metal in the way. can anyone who has done this please help me asap??
post Dec 21, 2005 - 5:19 PM
best tool ive found to get the tranny seals out is a "t-bar" seal remover,
its basicly a handle with hook shaped things on the end of it, it almost looks like a T. i got mine at the local autozone.
post Dec 21, 2005 - 5:35 PM
jermyd1
Joined Jun 2, '04
yea i have the tool but there seems to be a metal plate in front of the seal and its diameter is alot smaller than the seal's. should i try to pry that piece out?
post Dec 21, 2005 - 6:32 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Use the seal puller to pry the seal out. Dont worry about anything else.
Clean the hole before installing the new seal.
I will return one day.
post Dec 22, 2005 - 1:23 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
the driver and pass. are basically the same. There is no metal on the seal. Just take a good flat screwdriver and start working ur way around the seal. Shove the screwdriver into the hole and slowly pry it out. Don't worry cause the whole thing is part metal and hard plastic.
post Dec 22, 2005 - 4:45 PM
jermyd1
Joined Jun 2, '04
QUOTE(soulshadow @ Dec 21, 2005 - 10:23 PM) [snapback]369962[/snapback]
youre exactly right, the aftermarket seal is all plastic so i was confused but now i know that the factory ones are part metal. thanks for the help everyone.
Lo-Fi Version Time is now: August 26th, 2026 - 1:44 PM
