> would these fit??
post Jan 3, 2006 - 5:06 PM
Valo666
Joined May 15, '05
From Toronto
I was lookin around TN's forums and a guy has a nice set of 5zigen Inperio F15's in Hyper black. He says they are 18x7.5 +42 offset. Would thouse fit??
EDIT: Pics of the rims user posted image
This post has been edited by Valo666: Jan 3, 2006 - 5:10 PM
post Jan 3, 2006 - 5:37 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
depending the bolt pattern... but u wouldnt want it tho smile.gif 42+ offset would stick it out from the car.... stock is 45+ and im running 48+ and im a little sucked in...
feel free for anyone to correct me.
post Jan 3, 2006 - 7:17 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Blakout16 @ Jan 3, 2006 - 10:37 PM) [snapback]374191[/snapback]
stock is like +36... we can run as low as +30 offset and still be OK on a 7 in wide wheel... +42 @ 7.5 inches wide will still tuck in.
post Jan 3, 2006 - 7:51 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Kwanza26 @ Jan 3, 2006 - 6:17 PM) [snapback]374229[/snapback]
Actually, they will look almost identical to stock but will actually stick out about 4 more mm (because a stock GT wheel is only 7" wide).
post Jan 3, 2006 - 8:01 PM
97lestyousay
Joined Jul 7, '03
QUOTE(Blakout16 @ Jan 3, 2006 - 2:37 PM) [snapback]374191[/snapback]
You are running TenzoR Passion 5s right. Do you like em? I'm wanting the same but silver.
JDM guy made me do it.
post Jan 5, 2006 - 8:14 PM
Valo666
Joined May 15, '05
From Toronto
so they would fit? They r really nice rims and im gettin paid in about a week, so im gettin about $800. So compaired to stock, would they stick out? be tucked in? or would they be inline with the fenders? I kinda want the rims to fit so its almost fully flush with the fenders. I dont like how the factory GT/GTS rims sit inside. And bolt pattern is a universal 5lug. 10 Hole. So yay or nay? Fit or no?
post Jan 6, 2006 - 12:26 AM
WORK4POOP
Joined Jan 31, '03
From SoCal
What do you mean universal 5 lug? The bolt pattern for the celica is a 5x100. The wheels may have 10 holes because they have both 5x100 and 5x114. Be sure to check with whoever you are buying these from. It should have all info on the box... I would not buy these wheels. They have been discontinued so if you bust one you're boned. Also they are pretty damn heavy. An increse in unsprung weight will slow your already underpowered celi worse. But hey its you car do what you want...
post Jan 8, 2006 - 7:04 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I think they will be such inside the fender according
to my calculations.
6GC 4 Life Baby!!!
post Jan 8, 2006 - 1:22 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Valo666 @ Jan 5, 2006 - 7:14 PM) [snapback]375028[/snapback]
workpoop is correct. If its 5x100 it will fit if you dont buy tires with an overly large sidewall. As far as being "tucked in", they will look almost identical to stock. Actually, they will stick out 3-4 more mm which will not be noticable.
This post has been edited by jgreening: Jan 8, 2006 - 1:22 PM
Lo-Fi Version Time is now: August 25th, 2026 - 9:32 PM
