> 4AGE vs. 3SGE, Asking for comparison...
post Jan 9, 2006 - 10:32 AM
HUNK
Joined Jan 8, '06
From Satan's Television Set
Hey all. I'm looking into getting back into a 6th gen. For starters, I am trying to avoid getting a turbo engine, so I am trying to decide between the 20v blacktop and the 2nd gen 3SGE. Whether I go with the ST or the GT is really up to what I decide on for the swap. I'm mostly looking on advice as to how similarly these engines would perform. I know they're both rated at around 170hp, but the displacement difference has me wondering which would be better in which circumstances. I'm guessing the overall drivability of the 3sge is better, since it's more torquey. Drivability as in city traffic with lots of stopping and going. The celica seems kinda heavy to be putting a smaller displacement engine into, but I plan on removing as much weight from the car as possible. To that end, would the 4AGE be better on top speed, or the 3sge? On the same note, will the transmission that comes with the 20v fit directly onto the ST, or would there be modding involved?
Sorry if these are stupid questions, just trying to gather as much info as possible before jumping into a 6th gen. From what I've read so far, they're remarkably similar to the 5th gens, which is what I previously had. I'd mostly be using this car as a pleasure driver instead of a commuter, so yeah, I'm wondering which swap would feel/perform better if I was taking her out on the interstate. =D
Thanks, nice to be part of the community. ^^
post Jan 10, 2006 - 12:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
These engines don't perform similarly at all. I've driven both a 3SGE powered Corolla (AE86) and a 20V powered Corolla (AE86). The 3SGE has a much broader powerband than the 20V, which is fairly flat then picks up after 4-4.5K rpms. The 3SGE on the other hand doesn't have a "peak" so to speak... it sorta just climbs smoothly. Also note... the 3SGE makes max power at around 6500 rpms to 7000 rpms in the later models... while the 20V peaks upwards of 7800 rpms to 8000 rpms. Speed-wise... from a standstill... the 3SGE will out accel the 20V. From a roll... they'll be fairly even (2nd gen 3SGE vs. BT 20V).
BTW... if you're gonna get a 3SGE... get at least a 3rd gen (177-180hp). No point getting a 2nd gen. They cost pretty much the same. A 20V is an aquired taste... so only consider it if you like high revving peaky engines. Also, if you have an ST and want to swap in a 3SGE... gotta get mounts, axles, tranny, shift linkages, etc. The 20V is a direct bolt-in (minus some minor fab for accessories) into the ST. Likewise on the GT, the 3SGE is a direct bolt in, while the 20V requires mounts, tranny, shift linkages, axles, etc. The 20V tranny and the ST tranny are pretty much the same thing too. The 20V trans has shorter gearing and LSD optiuons and such, but the actual box is the same.
post Jan 10, 2006 - 1:26 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Also mod for mod the 3sge will always have more torque then the 4age. I have had many an argument with my stupid 4age buddy once I get a 4th gen I am gonna smoke the **** out of his little corrolla fair and square.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Jan 10, 2006 - 2:26 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(Agent21 @ Jan 10, 2006 - 6:26 PM) [snapback]376780[/snapback]
Made me sad for a minute. kindasad.gif I miss my '86 4th gen swap (2nd gen 3S-GTE) - that car was bad. Lots of problems though and horrible paint.
post Jan 10, 2006 - 7:33 PM
Agent21
Joined Sep 12, '05
Dude if you ever are in Georgia on a summer weekend near Road Atlanta stop by Lanier Speedway and you can see a racing 4th gen.
This post has been edited by Agent21: Jan 10, 2006 - 7:35 PM
94 GT Liftback
Lo-Fi Version Time is now: August 31st, 2026 - 5:48 AM
