> worn out CV boots
post Jan 14, 2006 - 8:33 AM
ToysRfast
Joined Dec 11, '05
From MN, Rochester
The CV boots right and left side are bad. The car starts to shake when I go faster then 60MPH and The car makes loud clicking sounds when I make left and right turns. The car also lost a lot of its power when I put the car in 1st gear it barely even moves. Everyone says the clutch burned out. I never smelled the clutch burn out and the clutch pedal is still stiff like it was when I bought my Celica. Anyway I placed an order for Inner and outer CV boot kits. With the problems I'm haveing do you guys think I should consider new Drive shafts? Would the loss of power be from the drive shaft or the Clutch?
post Jan 14, 2006 - 10:16 AM
The clicking sounds like CV boots. The lack of acceleration and shaking isnt characteristic of busted CV joints.
post Jan 14, 2006 - 8:15 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Shaking over 60 mph, wheel slipped a weight or the alignment is way out.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Jan 14, 2006 - 9:39 PM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
I got the same problem either before...
The only thing u can do is changing the all set of CV boots and joints..
It will mainly affect ur driving later if u don change it ......
post Jan 16, 2006 - 12:29 AM
jgreening
Joined Jan 17, '04
From Illinois
I agree with Super. Get those cv boots fixed quickly before you need new axels too.
Lo-Fi Version Time is now: August 31st, 2026 - 10:03 PM
