Jan 21, 2006 - 7:57 PM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
Ok guys i went to pepboys and bought this to weld to my oil pan
what do you think? Its made for a 3/4" hose its 1-3/4' long and the thread is 1/2" NPT. is it too small? ![]() Then i went to Ace hardware and bought 2 TEEs a nipple and plug and some thread seal tape. they had no crosses. but its all 1/8" Npt so what i'ma do is buy a male 1/8" BSPT to male 1/8" NPT and a male NPT to female BSPT. and everything should work out. ![]()
This post has been edited by southwest2118: Jan 22, 2006 - 4:43 AM |
Jan 26, 2006 - 12:45 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
i didn't even bother with the bspt adapter i took a 1/8" npt and it screwed right in. no problems with leaking at all.
This post has been edited by rjbibeau: Jan 26, 2006 - 12:46 PM -------------------- ![]() |
Jan 27, 2006 - 1:03 AM
the other day i spent f*ckin 25$ for one
male bs to male npt and male npt to female bspt. the female bs to male npt cost me 16$ WTF |
Jan 27, 2006 - 8:18 AM
why all the diffrent fittings??
just so you know, brass is about the worst thing you can use for those types of application, it is very weak and WILL crack. if all that stuff is what i think it is (turbo oil feed) then you need to take all those back where you got them from, and get this: http://tunertoys.zoovy.com/product/OTODK its got the proper thread pitch for the head and allows you to keep your stock pressure switch. the return needs to be 3/4" ID -------------------- Former Team 5SFTE pro member ;)
Jan 30, 2006 - 2:31 AM
too late buddy
Jan 30, 2006 - 2:38 AM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
who cares if its too late.
so, you wasted money, you might as well just do it right the first time instead of using all these different fittings that can be avoided, plus like manny said, brass is not the best for those types of applications |
Jan 30, 2006 - 7:38 AM
QUOTE too late buddy remember that statement when one of those crappy fittings crack, drain all your engine oil in a matter of seconds, and blow your motor to a bunch of nice sized paper weights -------------------- Former Team 5SFTE pro member ;)
Jan 31, 2006 - 12:57 AM
the t fittings are pretty thick and the adapters to bsp are stainless steel maybe the nipple will break but i put everything together and tryed to break it with my hand ....you think the temp will be a big factor? **** ...where other then the INTERNET can i get a cross? 1/8 npt female all around? steel? i would have bought that adapter that presure2 was talking about but f*ck it. just get the cross
Feb 3, 2006 - 3:02 AM
QUOTE(southwest2118 @ Jan 31, 2006 - 12:57 AM) [snapback]386838[/snapback] the t fittings are pretty thick and the adapters to bsp are stainless steel maybe the nipple will break but i put everything together and tryed to break it with my hand ....you think the temp will be a big factor? **** ...where other then the INTERNET can i get a cross? 1/8 npt female all around? steel? i would have bought that adapter that presure2 was talking about but f*ck it. just get the cross oh ya the temp and vibration will be a factor.....did you try pepboys? hardware store?....somebody else asked this question i can't remeber who? last week got oil pan welded. here it is.
| Lo-Fi Version | Time is now: August 4th, 2026 - 3:20 PM |
