> How to tell from a E153
post Jan 22, 2006 - 1:28 AM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
I was always curious of how to tell if the MR2 tranny was LSD(meaning the tranny is out of engine bay not connected to motor)? I was told that if you look though the axel hole, there should be a bar going across, but if a bar runs across the axle hole then how would the axle go in? Some body who knows please post...
post Jan 22, 2006 - 1:51 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(team_omega @ Jan 22, 2006 - 6:28 AM) [snapback]382162[/snapback]
Actually it's vise-versa. If you pull the axle and look in there, and there is a pin (the diff pin) visible, then you do NOT have LSD, it's an open diff. If there is no pin, then it's a Helical LSD.
The pin is deep in there, it doesn't interfere with the axle going in.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 22, 2006 - 1:54 AM
team_omega
Joined Aug 14, '05
QUOTE(Dr_Tweak @ Jan 22, 2006 - 1:51 AM) [snapback]382173[/snapback]
-Doc
What if i don't have the axles and only the tranny? Then how do i tell?
post Jan 22, 2006 - 3:21 AM
Dr_Tweak
Joined Mar 31, '04
You don't need the axles at all, you need to remove the axles if they are installed, and look in the hole in the tranny that they would go in.
-Doc
post Jan 22, 2006 - 10:59 PM
team_omega
Joined Aug 14, '05
QUOTE(Dr_Tweak @ Jan 22, 2006 - 3:21 AM) [snapback]382201[/snapback]
-Doc
Thanks for the info Doc
post Jan 22, 2006 - 11:30 PM
Does your axle hole look like:
this
this
or this?
This post has been edited by Supersprynt: Jan 22, 2006 - 11:43 PM
post Jan 23, 2006 - 12:39 PM
ZoomZoom
Joined Apr 7, '04
From Toronto
If you see a bar going across is also considered an lsd tranny
I think there are 2 kinds of lsd tranny for the mr2
the one with the bar
2nd one would be a big hole followed by the a small hole
The one with the bar across, I'm 100 % positive that it is an lsd coz thats what I have on my car right now.
the 2nd one, I'm not too sure about it.
Please correct me if I'm wrong
post Jan 23, 2006 - 12:45 PM
To MY knowledge, which contradicts Doc's and I dont like that, is that the bar means OEM LSD (2nd pic), the top pic is an open differential and the bottom is TRD LSD.
post Jan 23, 2006 - 1:39 PM
jgreening
Joined Jan 17, '04
From Illinois
The bar denotes the LSD. Here are some threads:
Thread #1
Thread #2
Thread #3
Thread #4
Thread #5
Thread #6
Thread #7
Thread #8
There are more, but I think you get the idea. There are posts in these threads from Jeff Fazio, BillWot, and Josh at Chico Race Works confirming the same thing. HTH.
post Jan 23, 2006 - 11:29 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(Supersprynt @ Jan 23, 2006 - 5:45 PM) [snapback]382750[/snapback]
I think you're right actually, I was going by how we tell with the E58 tranny which is the same thing as an E153 internally (pretty much), and I figured they would be the same...
I can't see a difference between the top and bottom pics though...
-Doc
post Jan 30, 2006 - 12:52 AM
team_omega
Joined Aug 14, '05
QUOTE(Supersprynt @ Jan 22, 2006 - 11:30 PM) [snapback]382575[/snapback]
this
this
or this?
I dont see anything like those pic on my tranny? And what is the difference between open differantial and LSD(what it does)? I know LSD spins both wheels but what does open differantial do?
post Feb 6, 2006 - 1:42 AM
eggman40
Joined Aug 17, '04
From California
correct me if am wrong but another way to tell if the tranny is equiped with lsd is when the axles are in place and you spin one wheel (while car is in air) the other wheel should spin in the same direction. Ex. if you turn the left wheel forward, than the right wheel should spin forward, and vice versa. if there is no lsd, then the wheels would spin opposite from each other. EX. push right tire forward, left wheels spins backward.
post Feb 6, 2006 - 1:48 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(eggman40 @ Feb 6, 2006 - 12:42 AM) [snapback]389517[/snapback]
Depends on the type of LSD you have. This method does not work for a stock LSD in an E-153.
post Feb 6, 2006 - 1:52 AM
eggman40
Joined Aug 17, '04
From California
[/quote]
this did happen to me when i put in my 92' e-153 in, and i do have that bar accross the hole in the picture, so does that mean my lsd is not stock or what?
post Sep 17, 2006 - 10:26 PM
funnys_tears
Joined Mar 30, '05
From Wisconsin
how can u tell is a lsd,
if i look in that axle hole i can see through the other side that does has a pin, that block both axle.
what if have pin in the middle of center...
the picture i am talk about the 2nd picture.
that spose to be non lsd or lsd
post Sep 17, 2006 - 10:47 PM
team_omega
Joined Aug 14, '05
QUOTE(funnys_tears @ Sep 17, 2006 - 10:26 PM) [snapback]480858[/snapback]
2nd pic is LSD
post Sep 21, 2006 - 12:09 AM
funnys_tears
Joined Mar 30, '05
From Wisconsin
my axle hole looke the 2nd picture then..wow i am lucky then i has lsd then, that awsome.. welp i got my from 3sge gt-r modle..hehehhe
post Sep 21, 2006 - 9:19 PM
team_omega
Joined Aug 14, '05
QUOTE(funnys_tears @ Sep 21, 2006 - 12:09 AM) [snapback]482112[/snapback]
the mr2 lsd have it...but it is kind of heard to explain...for example the mr2 lsd will have the bar in the hole and the mr2 non-lsd will not...but on the celica gt/st etc....the tranny has the bar in the hole too but doesn't have lsd...so i recommend you take the transmission id number to the dealer and look it up or i can do it for you...just pm me the transmission ID number....
Lo-Fi Version Time is now: August 26th, 2026 - 10:11 PM
