Feb 5, 2006 - 11:40 PM
Enthusiast ![]() ![]() Joined Aug 19, '04 From Maine Currently Offline Reputation: 0 (0%) |
Okay....So i was driving an extended distance andI go to shift all of a sudden I cant get into gear....... The only time I can put it into gear is when the car is shut off, OR if I let the car sit for a while it will work but then after warming up it does the same thing......any ideas?
Feb 6, 2006 - 12:08 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Sounds like your clutch is shot. If you force it into gear with the clutch in will it gring and go in? Or it just won't go in at all?
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 6, 2006 - 12:32 AM
It will not go in at all, the clutch was just replaced last year and then was fixed again by the same people a couple months later because they screwed up, i seriously think they did something...I know how to drive a standard........GRRR I just figured it could be the throwout bearing or something.....but hell if I know, either way im so pissed off at the garage that did it because I know it's their fault.
This post has been edited by d3monc3lica: Feb 6, 2006 - 12:33 AM |
Feb 6, 2006 - 1:35 AM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
did you check your engine oil??? It might be that because same thing happened to my brother's 5th gen celica.
Feb 9, 2006 - 1:56 PM
nah i topped off my hydraulic fluid for the clutch with some break fluid and its been working fine ever since....
| Lo-Fi Version | Time is now: June 22nd, 2026 - 10:09 PM |
