> Turbo engine!, Need help on building a Turbo Engine.
post Feb 8, 2006 - 7:06 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Hey guys, my next plan is to turbo charge a 20V 4age, but I still have some questions left un-touched about basic Turbo built engines.
Here they are answer away!
1.)
What type of Engine bearing do you guys use for TURBO engines?
2.) What kind of ROD do you use?
3.) Forged pistons are they way to go, but are there others and the best?
4.)What about the crank? Toyotas use steel crank I think!
5.) Duration and Cam lift, Which one works best?
6.) Headgasket?
7.) Oil-Pan, and Misc parts that need attention with Turbo setups.
post Feb 8, 2006 - 8:04 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
By these questions you posted, you pretty much know next to nothing regarding this subject. I suggest you read all the turbo threads in the forums and go to other websites of turbo cars so you can learn, because pretty much all the questions were kind of incorrect in terms of the way you worded them. Like duration and cam lift...why mess with that yet? Unless you REALLY need to touch that, you can skip that part. Depending on your mods, that will dictate what's correct...and usually, engines don't need that area altered unless you're pushing high horsepower or have some kind of problem. Forged pistons...and the best. There is no best out there...it's what you want/need. It's trial and error...there is no perfect recipe for a strong engine. The best built engines eventually fail, because that is just the nature of the beast. And if they don't, it's because they're rebuilt/freshened up after a few passes. Just read the stickies and search thr forums.
post Feb 8, 2006 - 11:01 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I shall hit it then, New cams are just there to get rid of the VVT.
post Feb 8, 2006 - 11:54 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
Oh ok I see...but anyway, read up...there is so much info about this from the members, it'll make your head spin! smile.gif
post Feb 9, 2006 - 6:03 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
You should visit Club 4AG (club4ag.com) and do as much research pertaining to turbocharging your 4AGE as possible. I know that I've heard that a popular move is to use the lower compression pistons of the 4AGZE but thats only the start im sure.
Research is your friend.
post Feb 9, 2006 - 6:37 PM
NGHTKD
Joined Feb 2, '06
club4ag.com the best 4AG site!!!, over here in Australia theres a lady by the name of Samantha Rigoli running a AE92 corolla with silvertop 20, t3/4 turbo equipped; has runned high 11's.
Try visit rigoli racing website or trp website
Lo-Fi Version Time is now: September 2nd, 2026 - 6:38 PM
