> 3sgte oil sensor question, another place to tap?
post Feb 8, 2006 - 9:49 PM
eggman40
Joined Aug 17, '04
From California
aside from the stock oil pressure sensor, is there another place on the head or the block that could be tapped to get a reading for a guage (oil press./oil temp)? or is a tee the only way to go? I know there are block adapters out there but thats out of the price range rght now. thanks
This post has been edited by eggman40: Feb 8, 2006 - 9:51 PM
post Feb 9, 2006 - 4:33 PM
eggman40
Joined Aug 17, '04
From California
bump
post Feb 10, 2006 - 7:18 AM
no.
post Feb 13, 2006 - 1:40 PM
eggman40
Joined Aug 17, '04
From California
I found another way to tap, i found this niffty product on a web-site. I ordered it and ill put up a product review depending on how well it works Oil temp adaptor
post Feb 13, 2006 - 8:32 PM
QUOTE(eggman40 @ Feb 13, 2006 - 1:40 PM) [snapback]393103[/snapback]
that will not work for oil pressure, only oil temp.
nifty tho.
post Feb 13, 2006 - 8:37 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(presure2 @ Feb 14, 2006 - 1:32 AM) [snapback]393349[/snapback]
nifty tho.
Yea i know it wont work for for pressure but i decided to get oil temp for now cause they discontinued the oil press. Heres another niffty tool for an oil pressure gauge. Oil press relocator
post Feb 13, 2006 - 8:43 PM
yea, there are all types of those...still gotta tap from the head for it tho
This post has been edited by presure2: Feb 13, 2006 - 8:44 PM
post Feb 13, 2006 - 8:47 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(presure2 @ Feb 14, 2006 - 1:43 AM) [snapback]393354[/snapback]
yea i figured that wink.gif but it beats having to to use a tee
This post has been edited by eggman40: Feb 13, 2006 - 8:48 PM
post Feb 15, 2006 - 1:13 AM
Green_MachToy
Joined Mar 21, '04
From Oceanside
Isn't there a hex bolt right in front of the stock sensor that can be removed to add the sensor he is talking about on the 3rd gen?
post Feb 15, 2006 - 2:13 AM
for the drain plug? i would worry about using that, because if the sensor probe sticks out a little and hits something on the road, youll loose your oil (and your motor) in a matter if minutes and not even know it .
post Feb 15, 2006 - 1:46 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(lagos @ Feb 15, 2006 - 7:13 AM) [snapback]394165[/snapback]
Thats true Lagos. Im gonna install it and judge the clearance. If it sticks out too much ill take it off.
This post has been edited by eggman40: Feb 15, 2006 - 1:46 PM
Lo-Fi Version Time is now: June 24th, 2026 - 4:43 AM
