> Tweaking your idle speed
post Feb 10, 2006 - 5:27 PM
TargetXeno
Joined Jan 22, '05
From Oakland, California
Does anyone out there know how to tweak the idle speed for the 5s-FE? I couldn't finish my emissions test because my idle speed was at 2200 rpm, I am trying to lower the value. Any expertise would be gladly appreciated.
post Feb 10, 2006 - 6:03 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
woah. 2200 rpm? lol, somethings wrong.
try seafoaming your car first, thats not right for it to being idling that high.
post Feb 10, 2006 - 6:44 PM
Alchemist_57
Joined Jun 12, '05
From Box Springs, GA
wat is the normal idle rpm for the 5SFE? also, wat it the normal top gear cruise rpm with the five-speed? In other words, wat SHOULD the tach read when doing 55-60mph on the highway?
Thanx
post Feb 10, 2006 - 6:50 PM
TargetXeno
Joined Jan 22, '05
wats seafoam has to do with this and the normal idle is 800 to about 1000
post Feb 10, 2006 - 7:22 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
normal idle is 750
post Feb 10, 2006 - 7:26 PM
TargetXeno
Joined Jan 22, '05
750? Thanks, but that's not the main point.
This post has been edited by TargetXeno: Feb 10, 2006 - 7:27 PM
post Feb 10, 2006 - 7:34 PM
LewFX
Joined Jan 28, '05
did you adjust your throttle cables, give it more slack.
post Feb 10, 2006 - 7:37 PM
Cutrara
Joined May 6, '05
From PA
Seafoam Engine cleaner. It removes carbon deposits. You pour 1/3 in your gas tank, 1/3 in your crankcase, and suck 1/3 in through a vacuum line. The car will stall, and when you start it up there will be ass loads of smoke. Let it idle for 10 mins, and when the smoke goes away, drive for about 200 miles then change your oil.
Edit: Try the seafoam before you mess with adjusting your cables, etc.
This post has been edited by Cutrara: Feb 10, 2006 - 7:38 PM
post Feb 10, 2006 - 7:39 PM
celicaST
Joined Jun 23, '05
your IAC (idle air control system) is probably not functioning correctly. get it checked, might need to replace IAC valve (if you have an ohmmeter resistance between terminals should be 19.3-22.3). by the way, also make sure all vacuum hoses and wiring is hooked up properly.
This post has been edited by celicaST: Feb 10, 2006 - 7:44 PM
post Feb 10, 2006 - 7:42 PM
LewFX
Joined Jan 28, '05
when was your last tune-up?
This post has been edited by LewFX: Feb 10, 2006 - 7:42 PM
post Feb 10, 2006 - 7:46 PM
TargetXeno
Joined Jan 22, '05
Been a loooong time lol.....
post Feb 10, 2006 - 7:52 PM
LewFX
Joined Jan 28, '05
tune it up before you do another test, spark plugs, wires, oil change, fuel filter change, new air filter. spray carb cleaner in the IAC too.
This post has been edited by LewFX: Feb 10, 2006 - 7:53 PM
post Feb 10, 2006 - 8:41 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Basics first before you get carried away rolleyes.gif . Sounds very much like there is an air leak somewhere in the system. A leaking vacuum hose etc will allow too much air into the intake side of the throttle body which will result in a high idle. Check all your hoses etc first.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Feb 10, 2006 - 8:47 PM
epinasty
Joined Oct 7, '05
From Kansas
You should be around 3000 rpm at 60mph. In 5th.
post Feb 10, 2006 - 9:53 PM
TargetXeno
Joined Jan 22, '05
QUOTE(GT4WRC @ Feb 10, 2006 - 8:41 PM) [snapback]392008[/snapback]
Gary
i checked all of the vacuum hoses soo thats not it and also i tried giving some slack in the throttle cable i even tried doing the sea foam just half an hour ago and was wondering is it a good thing or bad thing that there was no smoke coming out of the exhaust because alot of people said there would be alot of smoke coming out, i just felt a little bit of power thats all
post Feb 11, 2006 - 12:44 AM
GT4WRC
Joined Mar 17, '05
Make sure that none of them are split either. Very easy to miss that.
Gary
GT-Four spec list
post Feb 11, 2006 - 7:32 PM
TrdKing
Joined Feb 16, '05
From Brantford, Ontario, Canada
try adjusting the throttle positioning sensor
This post has been edited by TrdKing: Feb 11, 2006 - 7:33 PM
Lo-Fi Version Time is now: August 27th, 2026 - 1:00 PM
