Feb 17, 2006 - 12:47 AM
Enthusiast Joined Mar 28, '05 From New Jersey Currently Offline Reputation: 0 (0%) |
All right, so i got an ST, automatic, and definitley want to get a front clip(3sgte). When looking at clips, a majority of them are RHD, and therefore the stick shift is mirrored of that of a LHD celica, so whats the solution?
Feb 17, 2006 - 1:04 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
what are u trying to say...i'm misunderstanding you, but i dont comprehend what your trying to ask....u trying to see if u cna use the same shifter?
-------------------- ![]() Now SR powered |
Feb 17, 2006 - 1:09 AM
well its probably no problem to use the same shifter, but think about sitting normally, on the left, and following the layout of the shifter for a RHD, what should be the gears closest to you would now be farthest from you
Feb 17, 2006 - 2:29 AM
it is the same with LHD and RHD
QUOTE well its probably no problem to use the same shifter only if the clip is a 94-99 Celica -------------------- |
Feb 17, 2006 - 9:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
The only thing different is that the shifter is bent towards your leg (RHD) instead of away (LHD) so the feel will be a little different. But if you have not driven a Manual Celica before its nothing to worry about.
-------------------- JDM Powerplant installed, BPU coming very soon!
| Lo-Fi Version | Time is now: August 4th, 2026 - 9:18 AM |
