Feb 18, 2006 - 5:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 18, '04 From Portland OR / Vancouver WA Currently Offline Reputation: 0 (0%) |
How much weight does a full tank of gas add to our Celicas? Does it slow them down at all, or does it even weigh enough to matter?
I looked online & found a bunch of different answers for how much a gallon of gas weighs...some say 6.5lbs some say 8lbs. So I have no idea if a full tank adds 78lbs or 96lbs to our car. Someone help Oh & if this is a repost..then oops -------------------- ![]() |
Feb 18, 2006 - 5:57 PM
Enthusiast ![]() Joined Jun 12, '05 From Box Springs, GA Currently Offline Reputation: 0 (0%) |
i can't exactly tell, unless you're able to tell me the density of the fuel u use, it can vary with octane.
Feb 18, 2006 - 6:00 PM
![]() Enthusiast ![]() Joined Sep 18, '05 From NW North Carolina Currently Offline Reputation: 4 (100%) |
I believe density of gasoline changes depending on it's temperature. From what I read, the weight of gasoline at 72 degrees F is approximately 6.25 lbs per gallon.
So a little math: my GT has a 15.9 Gallon tank. If it is completely full, the weight of the fuel (at 72 degrees) will be approx. 99.375 lbs. Keep in mind, the colder the fuel is, the more dense it will become (thus heavier). The warmer the fule, the less dense (thus lighter). Hope that's right. Anyone else have any ideas on the matter? -------------------- |
Feb 18, 2006 - 6:08 PM
i think TheRockman got it right.
So, let's round off the celica's tank to 16gal. even. It's filled to the brim. At 72 degrees fahrenheit, the fuel in that tank will weigh exactly 100lbs. And like he said, the weight will vary with the temperature. -------------------- ![]() |
Feb 18, 2006 - 7:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
I dont notice that much difference in performance wise,
when having a full tank or not. But I wish the fuel gauge never goes down -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Feb 19, 2006 - 11:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
16 Gallon tank?! mine is only 12.6 gallons everytime i fill them up from empty? If i add more it will overflow..
Feb 19, 2006 - 12:11 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
yeah but the question- is that when it's on E, or below E-cuz' when it's on E there is still 4 gallons left.
Feb 19, 2006 - 12:39 PM
Enthusiast ![]() ![]() Joined Jul 14, '05 From Spring, Texas Currently Offline Reputation: 0 (0%) |
You mean when the gas light comes on?
Feb 19, 2006 - 12:42 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
QUOTE(TheRockman @ Feb 18, 2006 - 6:00 PM) [snapback]395975[/snapback] I believe density of gasoline changes depending on it's temperature. From what I read, the weight of gasoline at 72 degrees F is approximately 6.25 lbs per gallon. So a little math: my GT has a 15.9 Gallon tank. If it is completely full, the weight of the fuel (at 72 degrees) will be approx. 99.375 lbs. Keep in mind, the colder the fuel is, the more dense it will become (thus heavier). The warmer the fule, the less dense (thus lighter). Hope that's right. Anyone else have any ideas on the matter? that sounds right QUOTE(Fate @ Feb 19, 2006 - 12:11 PM) [snapback]396165[/snapback] yeah but the question- is that when it's on E, or below E-cuz' when it's on E there is still 4 gallons left. is that true, if so then i had no idea |
Feb 19, 2006 - 12:44 PM
I think once the gas light shows up you have around 3 gallons left. On Empty like 1.5 I assume.
Feb 19, 2006 - 12:57 PM
I think when mine gets down a lot again i'm going to have it cyphened out and see exactly how much
Feb 19, 2006 - 1:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 19, '05 From New York Currently Offline Reputation: 1 (100%) |
is this a reason why u drag with a 1/4 tank of gas? weight reduction
Feb 19, 2006 - 3:13 PM
Enthusiast ![]() ![]() ![]() Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) |
By adding weight to the gas tank you actually move the center of gravity lower and more toward the center of the car thus improving handling. I wouldn't know how to quantify the improvement but it could be significant given the added 100lbs.
Feb 19, 2006 - 3:58 PM
Enthusiast ![]() ![]() Joined Nov 25, '05 From Glasgow Currently Offline Reputation: 0 (0%) |
QUOTE(RocketScott @ Feb 19, 2006 - 3:13 PM) [snapback]396239[/snapback] By adding weight to the gas tank you actually move the center of gravity lower and more toward the center of the car thus improving handling. I wouldn't know how to quantify the improvement but it could be significant given the added 100lbs. anywho That was the end of that honda adventure ! -------------------- 351.5bhp RWD TT
Feb 19, 2006 - 4:07 PM
QUOTE(crismillencolin @ Feb 19, 2006 - 12:58 PM) [snapback]396253[/snapback] QUOTE(RocketScott @ Feb 19, 2006 - 3:13 PM) [snapback]396239[/snapback] By adding weight to the gas tank you actually move the center of gravity lower and more toward the center of the car thus improving handling. I wouldn't know how to quantify the improvement but it could be significant given the added 100lbs. anywho That was the end of that honda adventure ! Tire pressure, road/tire temperature, inexperience driving with full tank of gas. Could be anything. The physics of it are fairly simple though. To illustrate this another way: My truck rear end slides around fairly easy if it's unloaded. When I put all my tools in it's almost impossible for the engine to spin the rear tires or cut loose in a corner. |
Feb 19, 2006 - 4:11 PM
QUOTE(RocketScott @ Feb 19, 2006 - 4:07 PM) [snapback]396255[/snapback] QUOTE(crismillencolin @ Feb 19, 2006 - 12:58 PM) [snapback]396253[/snapback] QUOTE(RocketScott @ Feb 19, 2006 - 3:13 PM) [snapback]396239[/snapback] By adding weight to the gas tank you actually move the center of gravity lower and more toward the center of the car thus improving handling. I wouldn't know how to quantify the improvement but it could be significant given the added 100lbs. anywho That was the end of that honda adventure ! Tire pressure, road/tire temperature, inexperience driving with full tank of gas. Could be anything. The physics of it are fairly simple though. To illustrate this another way: My truck rear end slides around fairly easy if it's unloaded. When I put all my tools in it's almost impossible for the engine to spin the rear tires or cut loose in a corner. lol i think i was just looking to blame something other than my driving -------------------- 351.5bhp RWD TT
Feb 19, 2006 - 9:00 PM
my gas light usually come on when I hit 1/4 of a tank, and when i fill it up it right at the E and only 12.6G to fill up?
Feb 20, 2006 - 5:29 PM
QUOTE(95celgt @ Feb 19, 2006 - 6:00 PM) [snapback]396366[/snapback] my gas light usually come on when I hit 1/4 of a tank, and when i fill it up it right at the E and only 12.6G to fill up? serious??? mine light wont come on until it hits E....I think most everyones on here is like that -------------------- ![]() |
Feb 20, 2006 - 5:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 4, '03 From Kirkland, Washington Currently Offline Reputation: 0 (0%) |
128 oz = 1 gallon
16 oz = 1 pound 128/16 = 8 pounds per gallon If my math is correct then a full tank if its about 13 gallons = 104 pounds. DOes that math look right yall? QUOTE(TheStreetzKing @ Feb 19, 2006 - 10:12 AM) [snapback]396196[/snapback] is this a reason why u drag with a 1/4 tank of gas? weight reduction i think its cuz of weight and the fire department requires this so that incase ur car catches on fire you dont have a full tank of gas in there! -------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
Feb 20, 2006 - 5:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
celica fuel tank is 15.9 gallons
http://auto.consumerguide.com/Auto/Used/re...carreviewspecs/ and yes the reason people race with low fuel is because of weight, there is nothing reguarding safety or fire hazard. the only problem is you can run into issues with starving your fuel pump if you run too low due to sloshing and shifting of the fuel inside the tank, it also can begin to vaporize further increasing the chance of starving the motor. my friends saturn SC2 has a very well designed fuel tank and he has run many autox events when the fuel light has been on all day long, though i wouldnt recommend it. personally i try to run between 1/4 and 1/8 of a tank. but in all honesty the difference is negligable and you wont see a difference unless your skill level has hit a plateau and you are running very consistant times. oh and if i remember correctly you are mixing fluid ounces with a weight ounces that only works with distilled water nat This post has been edited by boosted_K2: Feb 20, 2006 - 6:00 PM -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Feb 20, 2006 - 5:57 PM
^^ i beg to differ...most dont ask u to have fuel cells in street classes so the track asks you not to run with more than 1/4 tank so incase ur car flips or something u dont have alot of gas! my dad use to race cars and thats what he said
This post has been edited by BlackCelicaGT94: Feb 20, 2006 - 6:05 PM -------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(BlackCelicaGT94 @ Feb 20, 2006 - 3:37 PM) [snapback]396771[/snapback] 128 oz = 1 gallon 16 oz = 1 pound 128/16 = 8 pounds per gallon If my math is correct then a full tank if its about 13 gallons = 104 pounds. DOes that math look right yall? QUOTE(TheStreetzKing @ Feb 19, 2006 - 10:12 AM) [snapback]396196[/snapback] is this a reason why u drag with a 1/4 tank of gas? weight reduction i think its cuz of weight and the fire department requires this so that incase ur car catches on fire you dont have a full tank of gas in there! no youre mixing fluid oz's and "mass" oz's. did a quick calculation, at .73 g/cc (average gasoline density, varies with temp and type) 15.9 gallons comes to 96.87lb, as calculated above. -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Feb 20, 2006 - 6:09 PM
ive never had an issue with that... maybe thats something they do with street mod drag cars, whenever ive been to a track and gone through tech ive never had an issue reguardless how much fuel ive had, then again im not an avid drag racer, but i asked a friend heres his answer:
K2MR2t91 (6:03:49 PM): is there any rules reguarding a limit to how much fuel you can carry when drag racing? obviously you want to run as little fuel as possible for weight, but is there a safety or fire hazard requirement? Smegamega 380 (6:04:04 PM): no well not for a street car K2MR2t91 (6:04:43 PM): ahh right, for like pro-mod and stuff there might be? Smegamega 380 (6:07:31 PM): for pro mod there is all classes and sanctioning bodies have there own set of rules, some require it, some do not. theres the answer This post has been edited by boosted_K2: Feb 20, 2006 - 6:10 PM -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Feb 20, 2006 - 6:11 PM
just cuz he said it doesnt make it an answer just like what my dad says doesnt make it THE ANSWER!
*though im more likely to side with an old man ;-) This post has been edited by BlackCelicaGT94: Feb 20, 2006 - 6:13 PM -------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
uhh... he currently participates in NHRA... i believe he would know the rules.
Feb 20, 2006 - 6:16 PM
^ congrats to him!
Feb 20, 2006 - 6:17 PM
no need to go anal on me lol all i was doing was showing we were both correct.
and the reason for asking my friend is i like to have credable evidance to support a claim i make unlike a lot of people on here. and no i am not saing "a lot of people" in reference to you, because i do realize your dad seems to be a pretty credable source as well from alot of the past info he has given you... thats one of the reasons i wanted to double check my info. So no, i am not attempting to attack you or discredit you or your father. I either make a statement where i know what i am talking about, keep my mouth shut, or blatantly say i dont know, i see no sense in fudging information because eventually you get called out on it. This post has been edited by boosted_K2: Feb 20, 2006 - 6:25 PM -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Feb 20, 2006 - 6:22 PM
This post has been edited by BlackCelicaGT94: Feb 20, 2006 - 6:22 PM -------------------- Cruisin down the street in my Infiniti...always lookin for my next trip to Sin City
Feb 20, 2006 - 9:35 PM
QUOTE(BlackCelicaGT94 @ Feb 20, 2006 - 5:37 PM) [snapback]396771[/snapback] 128 oz = 1 gallon 16 oz = 1 pound 128/16 = 8 pounds per gallon If my math is correct then a full tank if its about 13 gallons = 104 pounds. DOes that math look right yall? QUOTE(TheStreetzKing @ Feb 19, 2006 - 10:12 AM) [snapback]396196[/snapback] is this a reason why u drag with a 1/4 tank of gas? weight reduction i think its cuz of weight and the fire department requires this so that incase ur car catches on fire you dont have a full tank of gas in there! no your mixing up mass and volume, if that was true than water and gas would be the same density as jelly |
| Lo-Fi Version | Time is now: August 21st, 2026 - 7:16 PM |
