Mar 6, 2006 - 6:30 AM
![]() Enthusiast ![]() ![]() Joined Dec 6, '05 From South Carolina Currently Offline Reputation: 0 (0%) |
I have a few sound system questions.
I'm thinking of adding a sound system to my car by the end of May which gives me enough time to save up. Q1: What is the point in putting a Sub (8") in both side doors? Q2: How much should I roughly look at spending for the system (components in the front, 2 speakers in the back, headunit and a sub 10" with an amp)? I'd like to get one for qaulity and not the extreme bass. Q3: What should I look at when choosing a system? the Sensivity aka the dB? Q4: How do I calculate how much amp I need Q5: What can I do to stop the car from rattling once it is installed? I'm a n00b when dealing with cars -_-. |
Mar 6, 2006 - 7:00 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
Q1:
there is no point in it unless your addicted to speakers like me Q2: Money = Quality USUALLY however i left my stock speakers in after i switched to some aftermarket cause i liked them more Q3: not quite sure on this one but thats one thing i would compare along with placement/size/wattage Q4: there are 2 ratings: Peak Wattage = MAX power the speaker can handle RMS Wattage = what you should run it at Choosing an amp - match the RMS ratings it should give you optimal performance and chances are it will be hard to blow the speakers Q5: I used Dynamat and some old T-Shirts behind that carpet/plastic stuff and now it hardly rattles when i have it cranked (Dynamat isnt the only choice here I used BQuiet. It's pretty much the same but cheaper) Any other questions just PM or email me or something, Ill try to answer everything -------------------- -Brian
Mar 6, 2006 - 7:08 AM
Enthusiast Joined Feb 26, '04 Currently Offline Reputation: 0 (0%) |
QUOTE(JonCars17 @ Mar 6, 2006 - 11:30 AM) [snapback]403266[/snapback] I have a few sound system questions. I'm thinking of adding a sound system to my car by the end of May which gives me enough time to save up. Q1: What is the point in putting a Sub (8") in both side doors? Q2: How much should I roughly look at spending for the system (components in the front, 2 speakers in the back, headunit and a sub 10" with an amp)? I'd like to get one for qaulity and not the extreme bass. Q3: What should I look at when choosing a system? the Sensivity aka the dB? Q4: How do I calculate how much amp I need Q5: What can I do to stop the car from rattling once it is installed? I'm a n00b when dealing with cars -_-. A1 Subs in the doors aren't necessary. I would only get them custom built in along with the speakers. They will give your system some extra depth from the front. A2 This all depends on the brands. I'm not an expert on which brands make the best speakers/subs etc.. but I'd shop around and see what different stores offer, u can always test out their equipment. Usually the more $$$ u spend, the better the product. A3 Sensitivity is not dB-aka loudness. Sensitivity is the range of frequencies the speakers have a response to. It's the overall system that matters in the end. Your tweeters will cover the higher range, your front speakers mid to hi, ur rear speakers are bassier, and ur sub will cover the bass and the kicks. A4 When looking at the amp wattage, if u match the max watt output of both the amp and the sub, u cant go wrong. Again, ask the store ppls to give u advice on which amp, as prices do vary quite a bit depending on power output and type of amp. A5 Dynamat. They're thin sheets that absorb sound, making less sound escape the car and also slightly reducing road noise. I got it myself, it does work, and my boot rattles significantly less |
Mar 6, 2006 - 8:01 AM
So how is this?
CD Player: Alpine CDA-9856 Price: 200 RMS Watts: 18 Watts, Peak Power 50 x 4 channels Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 Speakers: Infinity Kappa 652.7i Price: 150 RMS Watts: 75, Peak Power: 225 Sub: Infinity Kappa Perfect 10.1 Price: 150 RMS Watts: 350, Peak Power: 1400 Amp: Infinity Reference 611a Price: 350 RMS Watts: 456 watts x 1 at 4 ohms/657 watts x 1 at 2 ohms This post has been edited by JonCars17: Mar 6, 2006 - 9:38 AM |
Mar 6, 2006 - 9:22 AM
Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Kentucky Currently Offline Reputation: 5 (100%) |
stay awau from polk, if your wanting a decent system for a cheap price...i would say bolt, because it is made by rockford fosgate.
-------------------- ![]() Cuz Thats How Us Country Boyz Roll Growing up racing motocross, i learned one thing..."Always wear clean underwear, you never know when the Paramedics are gonna have to cut your pants off of you" |
Mar 6, 2006 - 9:32 AM
QUOTE(6th_celi_vert @ Mar 6, 2006 - 9:22 AM) [snapback]403304[/snapback] stay awau from polk, if your wanting a decent system for a cheap price...i would say bolt, because it is made by rockford fosgate. I'm not really looking for a cheap system per say. Just trying to get a really good system for atleast under 1500. I may even up it to 2000 (max) Updated list above with Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 Speakers: Infinity Kappa 652.7i Price: 150 RMS Watts: 75, Peak Power: 225 I will tweak it as the days go by, every comment helps This post has been edited by JonCars17: Mar 6, 2006 - 9:37 AM |
Mar 6, 2006 - 11:10 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
i know this is very subjective... and a lot of people disagree but you don't really need rear speakers. they don't really add to the system... and u can use that money for even better quality equipment for other parts of ur system. a lot of people aren't used to it at first, but after a while they love it (no rear speakers)
you also might want to get 2 amps instead of 1 if you go to crutchfield site, they have kinda like a advisor thing that is quite useful. tells you what to look for in equipment, calcualting amps and stuff: http://www.crutchfieldadvisor.com/learningcenter/car/ you should read up a bit before spending that 1500-2000 of yours these links might help: Equipment recommendation: http://www.toyotanation.com/forum/showthre...95&page=1&pp=15 Elite car audio basics: http://www.elitecaraudio.com/search.php?query=&topic=1/ Basic car audio electronics: http://www.bcae1.com/ Car audio FAQ: http://www.faqs.org/ftp/faqs/car-audio/ for 1500-2000, you can get an INCREDIBLE system. $1000 can probably get you an awesome system already this might be of interest to you: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMESE%3AIT&rd=1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMESE%3AIT&rd=1 This post has been edited by elvasoshexai: Mar 6, 2006 - 11:23 AM -------------------- |
Mar 6, 2006 - 11:31 AM
Enthusiast ![]() ![]() ![]() Joined Jan 6, '06 From Oahu, Hawaii Currently Offline Reputation: 0 (0%) |
Okay, if you're going to use the Alpine SPR-17LS, you need a separate amp for those. I have those component speakers in my fronts too and they only sound good off an amp, not just the head unit. And you don't really need Infinity back speakers, this is your chance to save money. Back speakers are mainly to fill out your car. But i didn't know that before I bought back speakers. In my backs I have the SPR-17LP (Alpine Coaxial Speakers). But if you truly want those pairs of fronts and backs, then you need a 4 chan amp that puts out around 75W RMS @ 4Ohms per chan.
I got SPR-17LS Fronts SPR-17LP backs running off MTX-MXA6004 amp (4 chan 70W RMS @4 ohms). Sounds Crazy... Good luck... Yet |
Mar 6, 2006 - 11:53 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
I think you got a decent set up going there... ive heard some people complain about the Kappas, so id look around a little more on the sub, just to make sure you find what you want. Also i agree with vyet, you definatley want to get another amp to power your front components, and then use the deck to power your rear co-axs. and i think if you have the money, then you should definatley replace the rear speakers. Also pay attention to Ohms. They can differ from the amps. my .02
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
Mar 6, 2006 - 9:26 PM
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
QUOTE(elvasoshexai @ Mar 7, 2006 - 12:10 AM) [snapback]403327[/snapback] i know this is very subjective... and a lot of people disagree but you don't really need rear speakers. they don't really add to the system... and u can use that money for even better quality equipment for other parts of ur system. a lot of people aren't used to it at first, but after a while they love it (no rear speakers) This is true. For best SQ, most people will fade to the front (I do). I have my speakers faded about 11/15 to the front, rears are only for a little bit of rear fill, and for rear passangers. Having them too loud normally, drags your whole sound stage back. Splits (depending on the quality) should still sound better than stock speakers off the head unit. Head unit will put out about 18W rms, give or take, but as these guys have said, will sound A LOT better running off an amp. Even feeding them 50W rms, they will sound much better than stock speakers, or the splits off the head unit. But if you dont have the money right now, underpowering the fronts for the time being wont do them any damage. Just save up for a decent mono for the sub. Its better to have a decent mono amp for your sub, than to sacfrifice quality and get a sub-par 2 or 4 channel for your fronts/rears, and sub-par mono amp. If you want a quality sub, i'd personally stay away from Infinity. They've always seemed a pretty "cheap" brand. Have a look at Kicker, JL, Alpine, or less mainstream, Image Dynamics, or even DD, theres plenty of variety around. Go out and have a listen to these speakers yourself. It will sound different when in the car, but you'll have somewhat an idea of what they sound like. This post has been edited by ShadowFX: Mar 6, 2006 - 9:39 PM |
Mar 6, 2006 - 10:04 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
QUOTE(JonCars17 @ Mar 6, 2006 - 8:01 AM) [snapback]403284[/snapback] So how is this? CD Player: Alpine CDA-9856 Price: 200 RMS Watts: 18 Watts, Peak Power 50 x 4 channels Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 Speakers: Infinity Kappa 652.7i Price: 150 RMS Watts: 75, Peak Power: 225 Sub: Infinity Kappa Perfect 10.1 Price: 150 RMS Watts: 350, Peak Power: 1400 Amp: Infinity Reference 611a Price: 350 RMS Watts: 456 watts x 1 at 4 ohms/657 watts x 1 at 2 ohms thats a good moderate system there |
Mar 7, 2006 - 6:39 AM
yeah it is, but I modded it early yesterday, I'm thinking of going with all Alpine.
CD Player: Alpine CDA-9856 Price: 200 RMS Watts: 18 Watts, Peak Power 50 x 4 channels Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 Speakers: Alpine Type-R SPR-17LPi Price: 150 RMS Watts: 50, Peak Power: 250 Sub: Alpine SWR-1242D Price: 200 RMS Watts: 500, Peak Power: 1500 1st Amp: Alpine MRP-F450 Price: 300 70 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms), 200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode) 2nd Amp: Alpine MRD-M1005 Price: 550 RMS Watts: 700 x 1 at 4 ohms/1000 x 1 at 2 ohms but like I said I'll probably continue to change it as the days go by. The back speakers are up in the air, so I still donno if I want to get them or not. Overall price is 1800 but that is before tax and shipping. I think if you order from Crutchfield then shipping is free, could be wrong thou. I'll probably have to do some major lying on this one thou. If my parents found out I bought (future) a 1800 sound system they be on my back til They/I die. My mom is already on me for spending 1000 on body to my car -_-. This post has been edited by JonCars17: Mar 7, 2006 - 6:42 AM |
Mar 7, 2006 - 6:53 AM
Thats a pretty decent system. Alpine do make great gear, and the system will be loud, and sound great.
Just want to point out but, its not (mostly always not) going to be the best system, by going all one brand. Gear doesnt "match" up with other audio components of the same brand. It may have extra features, such as Alpine amp control being able to be controlled by some Alpine HU, but theres no audiable advantage with matching brands, unless of course, that particular brand makes the best of those two products. This post has been edited by ShadowFX: Mar 7, 2006 - 7:14 AM |
Mar 7, 2006 - 8:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
QUOTE(6th_celi_vert @ Mar 6, 2006 - 9:22 AM) [snapback]403304[/snapback] stay awau from polk, if your wanting a decent system for a cheap price...i would say bolt, because it is made by rockford fosgate. Stay away? I havent had a single problem and have had my stuff for over a year. -------------------- |
Mar 7, 2006 - 8:15 AM
Enthusiast ![]() ![]() Joined Sep 19, '05 Currently Offline Reputation: 3 (100%) |
I personally ended up going with 8" subs in the doors because I wanted good bass without sacrificing the vert's already small trunk. I assume you are no longer going that route; especially because you already have selected quite a beefy sub. However, if you are not an absolute bass fanatic and don't mind dynamating your doors, you can get two JL Audio 8w0's. They fit your doors with some very minor dremeling for the magnet. JL Audio always underrates their speakers; I've got a pair of 8w0's running at 130w rms apiece and have had no problems so far. As long as you are not an aggressive user and have clean power (don't overdrive the amp), going half-again as much power with JL's is not a problem.
It's probably not the solution you're looking for, but figured I'd let you know. 8w0's are about $90 apiece, and are only sold by dealers, so you can't get them off the internet. -------------------- |
Mar 7, 2006 - 9:12 AM
QUOTE(JonCars17 @ Mar 7, 2006 - 6:39 AM) [snapback]403846[/snapback] [..] Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 [..] if you end up not getting the rear speakers, with the money you save you might wanna try looking into the alpine type-x components? This post has been edited by elvasoshexai: Mar 7, 2006 - 9:13 AM -------------------- |
Mar 7, 2006 - 10:18 AM
QUOTE(elvasoshexai @ Mar 7, 2006 - 9:12 AM) [snapback]403865[/snapback] QUOTE(JonCars17 @ Mar 7, 2006 - 6:39 AM) [snapback]403846[/snapback] [..] Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 [..] if you end up not getting the rear speakers, with the money you save you might wanna try looking into the alpine type-x components? The site (Crutchfield) didn't have the Type-X components which is why they aren't on the list. I'll check a site later on when I get another break from work. Yesterday I had off so I could look and pick all day AMP 1: CD Player and 12" Sub AMP 2: Front components and Rear speakers I was planning on buying them in this order: CD Player Sub Amp amp 2 component rear speakers (if I get them) Edited: Went ahead and ordered my sub. I found one for 82 dollars cheaper than price stated above Link: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMEWN%3AIT&rd=1 This post has been edited by JonCars17: Mar 7, 2006 - 1:32 PM |
Mar 7, 2006 - 9:54 PM
QUOTE(JonCars17 @ Mar 7, 2006 - 6:39 AM) [snapback]403846[/snapback] yeah it is, but I modded it early yesterday, I'm thinking of going with all Alpine. CD Player: Alpine CDA-9856 Price: 200 RMS Watts: 18 Watts, Peak Power 50 x 4 channels Component Speakers: Alpine Type-R SPR-17LS Price: 250 RMS Watts: 70, Peak Power: 350 Speakers: Alpine Type-R SPR-17LPi Price: 150 RMS Watts: 50, Peak Power: 250 Sub: Alpine SWR-1242D Price: 200 RMS Watts: 500, Peak Power: 1500 1st Amp: Alpine MRP-F450 Price: 300 70 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms), 200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode) 2nd Amp: Alpine MRD-M1005 Price: 550 RMS Watts: 700 x 1 at 4 ohms/1000 x 1 at 2 ohms but like I said I'll probably continue to change it as the days go by. The back speakers are up in the air, so I still donno if I want to get them or not. Overall price is 1800 but that is before tax and shipping. I think if you order from Crutchfield then shipping is free, could be wrong thou. I'll probably have to do some major lying on this one thou. If my parents found out I bought (future) a 1800 sound system they be on my back til They/I die. My mom is already on me for spending 1000 on body to my car -_-. now thats a system |
Mar 8, 2006 - 1:57 PM
Yes, it will be damn sweet with that in. I spent like $600 tops for mine.
Mar 8, 2006 - 9:52 PM
Enthusiast ![]() Joined Apr 19, '05 Currently Offline Reputation: 0 (0%) |
i'm just gonna throw this out there, sorry im not great on specifics:
front: 6 1/2 component Infinity Kappa rear: 6 1/2 Infinity Kappa sub: Kicker L7 10'' i've heard all of these pieces, and they really sound amazing. |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 5:23 PM |
